[ROM][AOKP][PORT] AOKP for the DX2 and the MX2 [8/4/12]
This is a discussion on [ROM][AOKP][PORT] AOKP for the DX2 and the MX2 [8/4/12] within the Droid X2 ROMS forums, part of the Droid X2 Hacks category; Originally posted by CrazyLikeGollum over on XDA. All credit goes to him. AOKP - Milestone 6 for the DX2/MX2 This is a port of the ...
  • 1 Post By DirtyDroid
Thread: [ROM][AOKP][PORT] AOKP for the DX2 and the MX2 [8/4/12]
    Points: 28,483, Level: 99
    Level completed: 9%, Points required for next Level: 1,517
    Overall activity: 37.7%
    7,093
    338 times
    This is a port of the milestone 6 AOKP build available for the Atrix 4G (made by Th3Bill), using DzK's CM9 Alpha 5 as a base. From my testing on my MX2 it would appear that it is about as stable as DzK's CM9. There is a build for the MX2 that has DzK's wifi patch integrated and the kernel check removed, and there is a build for the DX2 that has the kernel check and no wifi patch. I take no credit for any of this, all I did was port it over and add a 1% Battery Mod (sort of)
    What Works:
    -Data/3G
    -WiFi
    -SMS
    -Camera*
    -Phone/Email/Contacts/etc.
    -Bluetooth
    -Data Usage
    -AOKP ROM Control
    -1% Battery Mod**
    -All that other important stuff
    *Camcorder does not record video, it opens, it zooms, but it doesn't record. "
    Videocam illusion" has been verified working on MIUI, give it a shot.
    **1% Battery Mod is on the status bar only, lockscreen will still show increments of 10%
    Issues:
    -On first boot homescreen glitches out after set-up. Fixed by hitting okay to all of the “hints” that pop up, then changing the wallpaper.
    -Rare random reboots.
    -4G section in settings crashes the settings app since we don’t actually have 4G.
    -Assumably any issues with CM9 Alpha 5 will still show up here.
    -If you find anything else let me know.
    Same rules that apply for flashing CM9 Alpha 5 apply here. So, you can flash over CM7/CM9 or Blur but always wipe /data and /cache, I recommend wiping /system as well. TiBU app restores for system apps are still a no go.
    Download page
    Download ICS GApps
    Instructions: YOU MUST BE ON ROOTED ANDROID 2.3.4 TO FLASH THIS ROM.
    1. Boot into recovery.
    2. Nandroid.
    3. Wipe Data/Factory Reset. Wipe Cache. Format System. Wipe Dalvik cache.
    4. Flash ROM.
    5. Flash GApps.
    6. Wipe Dalvik cache and fix permissions.
    7. Reboot.
    8. If boot hangs on the big “M” do a battery pull and start it up again. It might take a few tries.
    9. After a few minutes Set-up will load.
    10. Follow the prompts until you get to the homescreen.
    11. There will be three hints that pop up while your homescreen is glitching. Just tap the okay button on the first one, open your app drawer for the second, and tap okay again for the third.
    12. Long-press on the homescreen and change your wallpaper to get it to stop glitching.
    13. If you want any of the apps I removed back, download Removed-apps (NOT flashable).zip from the above zip and unarchive and push the apps you want to /system/app/ then set permissions to match the rest (0644 for those of you using chmod in terminal).
    14. You must use DZK's patched BSR when on this rom.
    15. Enjoy.
    X2 MMS Fix (No more GoSMS work around!!) Edited, posted by Twitish
    Hello all! Now, before we get all flustered, I would like to apologize for the faulty flashable zip I created earlier. I'm not the best at creating flashable zips, I'm still learning. Until this issue is worked out, we must fix our phones the manual way.
    This mod will replace the default apn-conf.xml in the /system/etc directory.
    Please note, I am not responsible for a loss of data, messages or missed phone calls that lose your job. (Even though it will all work the same, have to defend myself.)
    This fix is built into the latest MIUI by myself. Soon, other developers will place this in their ROMS making this thread not necessary.
    If you have created an APN yourself, it needs to be deleted.
    Also, I do not have an MX2, the carriers in this file are verified to work. If your carrier is not listed below, DO NOT DO THIS MOD!
    Carriers Supported:
    • Verizon
    • MobiPCS
    • Cricket
    • MetroPCS
    • Sprint
    • Virgin Mobile
    • Boost Mobile
    Now, onto the fix:
    1. Download this file here (Right Click, Save-As)
    2. Place it in the root of your SD Card
    3. Open Root Explorer, Root Browser Lite (Recommended), ES File Explorer, etc. (As long as it has root privileges)
    4. Rename your /system/etc/apn-conf.xml to /system/etc/apn-conf.xml.bak
    5. Copy the apn-conf.xml from your SD Card to /system/etc/
    6. Set the permissions to rw-r--r--
    [x][x][ ]
    [x][ ][ ]
    [x][ ][ ] (This is what it should the permissions box should look like)
    7. Go to the directory /data/data/com.android.providers.telephony/databases
    8. Remove telephony.db and telephony.db-journal
    9. Reboot phone.
    10. Enjoy a working MMS.
    Credit goes to Alias8886 in the Epic 4G forums.
    MX2 MMS instructions:
    1. Download the app "APN settings shortcut" from Google Play.
    2. Do a Google search for your carriers APN settings.
    3. Place the "APN settings shortcut" widget on your homescreen and tap it.
    4. Change the current APN settings to the correct ones by tapping on the first available set of settings in the first menu and changing each field as necessary according to the settings you found in your Google search.
    5. Back out of the menu and exit the app.
    6. Congratulations you should have working MMS now.
    *** V6 Supercharger is confirmed working with this ROM, so enjoy!
    Credits:
    AOKP Team - For the Original AOKP.
    Th3Bill - For the Atrix 4g ROM I ported from.
    DragonzKiller - For his CM9 Alpha 5 that I used as a base.
    Angus MacGyver @ Rootzwiki - For the Boot Animation
    Screen Shots posted by UbuntuBrandon
    uploadfromtaptalk1344172795503.jpguploadfromtaptalk1344172810866.jpguploadfromtaptalk1344172823241.jpguploadfromtaptalk1344172833609.jpguploadfromtaptalk1344172862856.jpg
    Disclaimer..I nor dxf are responsible for what you do to your device.
    7,093
    338 times
    Op updated, mms fixed.
    Points: 45,910, Level: 100
    DirtyDroid's Avatar
    28665
    Upstate,NY
    14,576
    384 times
    And one more lol
    tap'd from the Gnex
  1. [ROM] AOKP [unofficial]
    By x13thangelx in forum Ice Cream Sandwich ROMs
    Last Post: 05-11-2012, 04:21 PM
  2. Wtf aokp
    By sixxstarz in forum AOKP
    Last Post: 04-30-2012, 06:56 PM
  3. Wtf aokp
    By sixxstarz in forum Droid X ROMs
  4. [ROM] AOKP [Unofficial] 4-17
    By x13thangelx in forum AOKP
    Last Post: 04-21-2012, 03:45 PM
  5. [rom] aokp b32 [unofficial] [4/11]
    Last Post: 04-17-2012, 03:50 AM
aokp droid x2
aokp for droid x2
aokp for droidx2 ics
aokp rom droid x2
aokp rom for droid x2
atrix 4g milestone6 mx2 rom
atrix 4g th3bill
cm9 dx2
dx2 roms
mx2 rom
