[ROM][PORT][KANG] ParanoidAndroid v1.6 DX2 (7/31/12)
This is a discussion on [ROM][PORT][KANG] ParanoidAndroid v1.6 DX2 (7/31/12) within the Droid X2 ROMS forums, part of the Droid X2 Hacks category; First off: I DO NOT claim to be a developer, I simply ported this from the Atrix 4G. It is working on my phone, but ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: [ROM][PORT][KANG] ParanoidAndroid v1.6 DX2 (7/31/12)
    Points: 28,483, Level: 99
    Level completed: 9%, Points required for next Level: 1,517
    Overall activity: 37.7%
    7,093
    338 times
    First off: I DO NOT claim to be a developer, I simply ported this from the Atrix 4G. It is working on my phone, but I am not responsible for any problems/damage this may cause with yours! I will try to fix any bugs, but no promises.PLEASE follow the directions to avoid confusion
    Want to be up to date with ParanoidAndroid project news?, click here, and visit the official webpage!
    • Download PA1.6port_09032012-signed and gapps-ics-20120511-fixed.zip
    • MX2 users go to this post for download link and thank 754boy. You will still need the GApps from the above as well as the wifi patch as stated in 754boy's posts.
    • Milestone X2 Users ONLY. Wifi Patch http://d-h.st/Pdy
    • Install ROM
    • Install *HYBRID* GApps
    • Wipe cache/dalvik cache. Factory reset is a must if you're coming from any ROM besides CM9 (will have to wipe data if coming from first PA port to get MMS to work, thanks to dzk for mms)
    • *IMPORTANT* CWM -> Advanced -> Fix Permissions
    • Reboot
    • If you're having trouble make sure to fix permissions
    • Most app compatitibity problems come from not installing the hybrid GApps
    • Check out Paranoid Settings
    • For onscreen softkeys (even though they're tiny) Settings->System->Navigation bar
    • Wallpapers (info here) and bootanimation now included in ROM. For a two part boot animation download here, rename to bootanimation.zip and put in /data/local/. Both bootanimations thanks to catawalks.
    • CM wallpapers here in case you miss them.
    • You will need to use DZK's patched BSR when on this rom.
    • Install Video Illusion for working camcorder.
    • Settings-> About Phone FC's as well as Settings-> Advanced-> Idle stats
    • This will have the same issues as CM9 has
    • Please let me know of any bugs
    • CyanogenMod team for CM9
    • DZK for bringing CM9 to our device
    • ParanoidAndroid Team (molesarecoming and d4rkn3sys) for making the ROM
    • Th3Bill (awesome guy) and Team Moto Tegra for their port to the Atrix 4g
    (9-3-2012)
    • Updated base to CM9 Beta 1
    • Included bluesleep fix by olegfusion and Th3Bill from Team Moto Tegra, Thanks to twitish for finding it.
    • Added SuperSU in place of regular SU
    **Originally posted by csking33 over on XDA, all credit goes to him**
    Disclaimer... I nor dxf are responsible for what you do to your device..
    7,093
    338 times
    Updated zip in OP. Will fix MMS Please note this does require a data wipe.
    New zip also includes boot animation as well as PA wallpapers.
    7,093
    338 times
    Preferred system fixed!!
    Updated link in OP. Make sure you flash 080912 zip for the fix! Removed 080812 to avoid confusion when downloading.
    Points: 45,910, Level: 100
    DirtyDroid's Avatar
    28665
    Upstate,NY
    14,576
    384 times
    Added disclaimer and stuck..:thumbup:
    tap'd from the Gnex
    Themer
    Points: 3,997, Level: 40
    Level completed: 24%, Points required for next Level: 153
    jdcmusicman's Avatar
    46668
    Aug 2011
    Earth
    399
    12 times
    I tried flashing this on my gals dx2 and it wouldnt install , just said there was an error (status 7) and installation aborted..Is there any thing I am missing , I followed the instructions
    7,093
    338 times
    Did you follow the instructions to a T? and are you on 2.3.4? and what was she running before trying to flash this?
    If those all check out, make sure the download wasnt corrupt.
    Edit: ok since it wasn't 2.3.4 be sure to past back and let us know how it goes.
    Themer
    46668
    Aug 2011
    Earth
    399
    12 times
    Got to looking and she wasnt on 2.3.4 , I am sbf ing right now , going to give it another shot after i get it rooted and stuff..Thanks for the quick response
    7,093
    338 times
    Great, hope it works out for you.
    On a side note original post updated to state you must be on 2.3.4. My bad for not including that from the beginning.
    Themer
    46668
    Aug 2011
    Earth
    399
    12 times
    Up and running , man this rom is great , I wish they had it on the X
  1. Droid X ICS Port is here.
    By BHuber09 in forum Droid X ROMs
    Last Post: 12-20-2011, 12:54 PM
  2. How to port themes to DX?
    By budmonster in forum Droid X Themes
    Last Post: 06-29-2011, 11:29 AM
  3. Playing M3p Through car usb port
    By otis in forum Droid X Rescue Squad
    Last Post: 01-16-2011, 08:10 PM
  4. HDMI port
    By stevewitt in forum Droid X General Discussion
    Last Post: 10-26-2010, 07:56 PM
  5. What is the USB port on the VZ car charger for?
    By Wicken in forum Droid X General Discussion
    Last Post: 10-05-2010, 03:54 PM
droid x paranoid android
droid x2 paranoid android
droid x2 roms
dx2 roms
paranoid android droid x
paranoid android droid x2
paranoid android status 7
paranoid android x2
paranoid droid x
paranoidandroid droid x
