[ROM][PORT][KANG] ParanoidAndroid v1.6 DX2 (7/31/12)
This is a discussion on [ROM][PORT][KANG] ParanoidAndroid v1.6 DX2 (7/31/12) within the Droid X2 ROMS forums, part of the Droid X2 Hacks category; Originally Posted by GoCliffGo05 This ROM has the same issues listed as CM9 since it is built from it. Browser crashes, FC's. Etc. Its definitely ...
Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: [ROM][PORT][KANG] ParanoidAndroid v1.6 DX2 (7/31/12)
  1. #21
    Points: 93, Level: 1
    Level completed: 86%, Points required for next Level: 7
    Thasian's Avatar
    63083
    Nov 2012
    Virginia
    This ROM has the same issues listed as CM9 since it is built from it. Browser crashes, FC's. Etc. Its definitely worth flashing once to check it out... make a nandroid of CM7, flash this ROM, if you don't like it just restore the CM7 backup, no wipes needed.
    Thank you, I will give it a shot after Christmas. I have tried CM10, and it was a bit too unstable, so thought I would try something different, so again, thank you
  3. #22
    Points: 26,735, Level: 97
    Level completed: 39%, Points required for next Level: 615
    Overall activity: 30.9%
    7,093
    338 times
    No problem at all.
  4. #23
    Thasian's Avatar
    63083
    Nov 2012
    Virginia
    My DX2 has PA v1.6 installed. Few strange things have happened, but pulling the battery and rebooting seem to get things back on track. The strangest, when I go into system settings and click on "about phone" I get a FC. But using MyDroid will show most of what "about phone" will show.
    I have tried most everything except BT and GPS, and so far no real issues. I use PDAnet for teather, videocam illusion for video and MyData to track data usage. They all seem to work.
    I will continue to test over the next couple of weeks and if I run into anything strange I will let you know, but so far ROM seems to be very stable. And at first seemed to drain the battery very fast, but now seems to be every bit as good, if not better than CM7 on my battery.
    Thanks for a what is looking to be a very good ROM.
  5. #24
    Thasian's Avatar
    63083
    Nov 2012
    Virginia
    Quote Originally Posted by Thasian View Post
    Should have added, I use Button Savior for on screen soft keys and it seems to work as well.
    Again, thank you
  1. Droid X ICS Port is here.
    By BHuber09 in forum Droid X ROMs
    Last Post: 12-20-2011, 11:54 AM
  2. How to port themes to DX?
    By budmonster in forum Droid X Themes
    Last Post: 06-29-2011, 10:29 AM
  3. Playing M3p Through car usb port
    By otis in forum Droid X Rescue Squad
    Last Post: 01-16-2011, 07:10 PM
  4. HDMI port
    By stevewitt in forum Droid X General Discussion
    Last Post: 10-26-2010, 06:56 PM
  5. What is the USB port on the VZ car charger for?
    By Wicken in forum Droid X General Discussion
    Last Post: 10-05-2010, 02:54 PM
droid x paranoid android
droid x2 paranoid android
droid x2 roms
dx2 roms
paranoid android droid x
paranoid android droid x2
paranoid android status 7
paranoid android x2
paranoid droid x
paranoidandroid droid x
