CM7.2 acting up after cleaning up SD card.
This is a discussion on CM7.2 acting up after cleaning up SD card. within the Droid X2 ROMS forums, part of the Droid X2 Hacks category; I have been running c m 7 4 quite some time now. it has worked quite well for me up until recently. I cleaned out ...
Thread: CM7.2 acting up after cleaning up SD card.
    Points: 1,274, Level: 19
    Level completed: 74%, Points required for next Level: 26
    shagg9's Avatar
    40356
    57
    I have been running c m 7 4 quite some time now. it has worked quite well for me up until recently. I cleaned out my sd card and now it has gone berserk. I am getting it force closes every other minute on all sorts of applications and system. can I just reflash cm 7 over itself? do I need to do anything differently ?
    Sent from my cm7.2 using Droid X Forums
    shagg9's Avatar
    40356
    57
    My biggest problem is that it will not connect to my pc anymore. it's always just does a couple reboots and never connects.
    Sent from my MB870 using Droid X Forums
    shagg9's Avatar
    40356
    57
    I reflashed cm7.2 and all is well
    Points: 52, Level: 1
    Level completed: 4%, Points required for next Level: 48
    unimatrix725's Avatar
    56063
    5
    Thanks for the tip.. I was going to suggest perhaps some apps are / were moved to sd card and not restored or were deleted. Back when I had a Sony x10 I had a similiar issue. It was because the poor phone had little space and I moved allot of apps to the sd card. Needless to say the x10 crapped itself big time.
  1. SD card cleaning
    By Carpetman in forum Droid X Help
    Last Post: 08-28-2011, 02:58 PM
  2. SD Maid System cleaning tool
    By wicked in forum Droid X Apps
    Last Post: 05-30-2011, 11:37 PM
  3. Great screen cleaning wipes for your X
    By DroidXterminator in forum Droid X Accessories
    Last Post: 01-16-2011, 11:37 AM
Droid x acting up
clean up droid x2
cleaning the droid x2
cm7 for razr
cm7 latest update for droid x
cm7.2 droid x
droid x2 cm7
droid x2 cm7.2
sd maid with cm7
why is my droid x acting up when i install my sd card
