Droid X2 ROM installing trouble
This is a discussion on Droid X2 ROM installing trouble within the Droid X2 ROMS forums, part of the Droid X2 Hacks category; I have a rooted Droid X2 and I have been trying to install a ROM on it. Specifically the Liberty ROM...but I don't know how. ...
Results 1 to 8 of 8
  • 1 Post By adamwhitehead
Thread: Droid X2 ROM installing trouble
    Points: 90, Level: 1
    Level completed: 80%, Points required for next Level: 10
    Overall activity: 0.7%
    notTHEsmartest's Avatar
    52042
    Nov 2011
    Exclamation Droid X2 ROM installing trouble
    I have a rooted Droid X2 and I have been trying to install a ROM on it. Specifically the Liberty ROM...but I don't know how. You are my last hope. I need specific step by step instructions.
    Points: 529, Level: 10
    Level completed: 58%, Points required for next Level: 21
    Tsmith1296's Avatar
    52071
    Nov 2011
    23
    Hello all. I am having trouble too. When I download liberty Tom on my computer it automatically opens file and shows two files. I don't have just a zip file to drag to my SD card. It opens file and shows medi file and shows system file. I moved both them to my SD. I am using rom manager but when I search for roms on SD nothing shows up. Sorry if I sound stupid this is my first rom install. Any help is greatly appreciated
    Points: 17,835, Level: 84
    Level completed: 97%, Points required for next Level: 15
    Overall activity: 1.6%
    juhde's Avatar
    38196
    New Mexico
    1,717
    59 times
    If you have access to wifi it is much easier to download ROMs directly to your phone. Most forum apps (tapatalk based like droid forums, droidx forums, xda, etc) allow clickable download links. Also a good browser has download options (opera, dolphin hd).
    Sooooo begin by downloading the ROM directly to your phone. Then move the zip file from /sdcard/download to the root directory of your external sdcard. If you are completely stock this should be /sdcard-ext (most ROMs have the external card mounted as /sdcard, so remember this for later, after you've flashed a ROM. The internal storage will be mounted to /sdcard-ext, basically flipped.)
    One thing, it's best to flash a ROM with a full battery, you can do it with a partial charge but it's much better to do it after a complete charge, it saves having to recalibrate the battery.
    After you've moved the zip file to the root directory of your external sdcard, you'll need to reboot into custom recovery. This is done with the app called system recovery, you'll have to download tenfars x2 bootstrap recovery from a forum and install it. Then launch system recovery, tap install recovery, plug the phone into a WALL OUTLET, then tap reboot recovery.
    Once in custom recovery you'll want to make a back up. Using the volume buttons to move the selection and the power button to choose it, do so now. Once the back up is finished you'll need to wipe data, wipe cache, and under advanced, wipe dalvik cache. Then choose install rom from zip, choose file from sdcard, scroll down to the ROM zip file and choose it, then confirm. Then ROM will now install, once finished choose reboot and unplug the device. The first boot takes a few minutes, re-setup your phone and re install your apps. You're done.
    If you don't like the ROM, simply boot back into custom recovery and restore the backup you made in the beginning, it will be like nothing happened.
    Sent from my Android device.
    Points: 3,473, Level: 36
    Level completed: 82%, Points required for next Level: 27
    Overall activity: 31.4%
    adamwhitehead's Avatar
    49777
    Oct 2011
    russellville, al
    282
    Very nice write up^
    52042
    Nov 2011
    I cannot thank u enough. You are awesome
    Sent from my newly liberated droid x2
    juhde's Avatar
    38196
    New Mexico
    1,717
    59 times
    Any time, always happy to help.
    Tsmith1296's Avatar
    52071
    Nov 2011
    23
    Yes I am thankful also. I can now say I'm rooted and.running liberty and it is so sweet. Thank so much
    49777
    Oct 2011
    russellville, al
    282
    Juhde is a beast
    victimssun likes this.
  1. Trouble Installing Liberty 3
    By Koopa Troopa in forum Team Liberty
    Last Post: 11-26-2011, 07:28 PM
  2. Trouble installing cm4dx
    By spideyx24 in forum Cyanogenmod
    Last Post: 10-08-2011, 02:33 AM
  3. Trouble installing via Appbrain
    By hooah212002 in forum Droid X Apps
    Last Post: 05-14-2011, 10:46 PM
  4. Trouble Installing Apps
    By HHundyy in forum Droid X Help
    Last Post: 01-03-2011, 08:15 AM
  5. trouble installing rom
    By boston0108 in forum Droid X Hacks
    Last Post: 11-20-2010, 06:03 AM
android x2 how to install rom
droid x2 rom install
how to download roms on droid x2
how to install a rom on droid x2
how to install liberty rom droid x2
how to install rom on droid x2
how to install roms on droid x2
how to put roms on droid x2
install rom droid x2
