problem with cm10 installation
This is a discussion on problem with cm10 installation within the Droid X2 Hacks forums, part of the Droid X2 Forum category; Have tried to install cm10 several times, keep getting this error. any help available?? Set_perm: some changes failed E:Error in/sdcard/cm-10=20121007-UNOFFICIAL-daytona.zip (Status 7) Installation Aborted Thanks...
Thread: problem with cm10 installation
    Thanks
    Points: 17,960, Level: 85
    Level completed: 22%, Points required for next Level: 390
    Overall activity: 99.8%
    6,240
    138 times
    A couple of things to check out. If you go to settings - about phone what android version are you on, 2.3.4 or 2.3.5? CM10 only works on 2.3.4. Or are you already on a ROM and trying to flash it over? If so what ROM?
    Secondly have you made sure the download is good? You can check the MD5 sum from the download page.
    Thirdly are you trying to install it through the X2 BSR and not stock recovery or ROM Manager or anything like that?
    Sent from my X2 using DXF
    6,240
    138 times
    Ok so I just saw you posted this over on XDA also...
    Here's what I need you to do for me please. Explain to me step by step how you are attempting to install the ROM. I know it sounds tedious but it will help a lot. Please be as specific as possible.
    Edit: you said you are wiping data before you install the ROM from stock 2.3.4? Don't do that. Boot into system recovery, flash the ROM, flash the GApps then wipe data and cache... see if that helps. If not post the steps like I previously asked.
  1. Installation Help
    By darkh in forum Cyanogenmod
    Last Post: 02-25-2012, 11:30 PM
  2. Help with Installation
    By Catastrophe in forum Gingerbread Development and Hacking
    Last Post: 05-29-2011, 08:30 PM
  3. gb help installation
    By drago11 in forum Gingerbread Help
    Last Post: 05-15-2011, 04:43 PM
  4. Help with ROM and installation
    By duramax07 in forum Hacking Help
    Last Post: 01-23-2011, 06:37 PM
  5. Help with ROM and installation
    By duramax07 in forum Droid X General Discussion
    Last Post: 01-18-2011, 06:30 PM
cm10 droid x
cm10 for droid x
cm10 installation aborted
cm10 status 7
droid x cm10
set perm some changes failed
set perm some changes failed status 7
set perm: some changes failed
status 7 installation aborted
status 7 installation aborted cm10
