Need help rooting, an non-rooted dx2 2.3.5
This is a discussion on Need help rooting, an non-rooted dx2 2.3.5 within the Droid X2 Hacks forums, part of the Droid X2 Forum category; i have a dx2 with v2.3.5 and my phone is not rooted. i have looked all over this web site and only find instructions of ...
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Need help rooting, an non-rooted dx2 2.3.5
    Points: 2,203, Level: 28
    Level completed: 36%, Points required for next Level: 97
    Overall activity: 7.0%
    brucebanner77's Avatar
    58852
    May 2012
    east tx
    31
    i have a dx2 with v2.3.5 and my phone is not rooted. i have looked all over this web site and only find instructions of how to root a dx2 2.3.4. I readl one thread of someone wanting to down grade to dx2 2.3.4, but their phone was already rooted when they took the update. i want to root a non-rooted dx2 2.3.5, totaly factory stock. I want to keep all my contacts, apps, pics and music. ANY help will be greatly appreciated.
    Points: 905, Level: 16
    Jo5060's Avatar
    33488
    7
    I have the same problem/desire. I have tried Petes, and other methods which do not work including DoomLord, which says the file system on the Droid X2 is read only for the file directories it is trying to copy into.
    Points: 18,811, Level: 86
    Level completed: 93%, Points required for next Level: 39
    Overall activity: 70.4%
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    the only way is to SBF to 2.3.4
    [How to] Root 2.3.5/1.3.418
    edit:
    backup contacts to gmail or verizon's backup assistant
    turn on restore apps in settings
    backup pics on pc or use photo bucket app (auto backups)
    backup music on pc
    backup texts and call log with sms backup +
    you may not have to lose data, when flashing SBF, only if you bootloop, then you have to wipe data
    many have not had to wipe data, but backup just in case
    58852
    May 2012
    east tx
    31
    So If I bootloop, I have to wipe all my data? (Please forgive me, I know absolutely nothing about any of this, I've been studying this stuff for 3 days)
    Sent from my DROID X2
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    wiping data is recommended, but many have flashed SBF, and not had to wipe
    give it a couple of mins to boot first time, before you panic
    and it's not a bad idea to boot into stock android recovery, just to know how, before you need to
    and you can try wiping cache, this will not delete any of your data, but may prevent bootloop
    data on the sd card is safe, from data wipe and SBF, but backup data on internal card
    the X2 has a locked bootloader, which means it's hard to brick
    58852
    May 2012
    east tx
    31
    I'm going to try this later tonight, is there ANYTHING else I need to know. I'm going to write all the steps on part first and go from there.
    58852
    May 2012
    east tx
    31
    Quick question, do I have to use a laptop or can I use my phones browser?
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    downloading files, from phone is fine
    rsd lite, and pete's need to run on pc
    edit: when you boot to rsd support all it will say is 'starting rsd support'
    also if you get into rsd support, and want back out, easiest way is battery pull
    Points: 2,002, Level: 27
    Level completed: 2%, Points required for next Level: 148
    Astimov's Avatar
    45065
    Aug 2011
    9
    I managed to SBF 2.3.4 without wiping data, but I had to do a factory reset which means I lost my apps. Though I kind of wish I had wiped it to use a clean install. The best method is to use RSD lite to SBF to 2.3.4. Root using Pete's method. Install Rootkeeper, perform a backup and unroot the phone. Update to 2.3.5, restore the backup and off you go.
    http://depositfiles.com/files/spvcfjb4w 2.3.4 SBF - 2.3.4 SBF
    Pete's Motorola Root Tools - Pete's root tools
    RSDLite5.3.1.msi - RSD lite 5.3.1 download
    I have not used the SBF file from this link so I don't know if it's good. I can't remember where I got the file I used.
    Astimov's Avatar
    45065
    Aug 2011
    9
    Quote Originally Posted by brucebanner77 View Post
    You can download everything with the phone, but you'll need a computer to SBF and use Pete's root tools. It's best to keep it simple and do everything on a computer, except OTA Rootkeeper is an Android app.
  1. Replies: 7
    Last Post: 08-05-2011, 07:33 PM
  2. any1 rooted having problems upgrading market on rooted x
    By aypeeootrek in forum Droid X General Discussion
    Last Post: 07-15-2011, 09:48 PM
  3. how to update rooted stock froyo to rooted gingerbread-HELP!
    By lilnba93 in forum Droid X General Discussion
    Last Post: 06-21-2011, 11:45 AM
  4. rooting and un-rooting question and suggestions
    By Richard3 in forum Hacking Help
    Last Post: 05-14-2011, 02:46 PM
  5. Replies: 12
    Last Post: 04-19-2011, 06:17 PM
droid x2 root 2.3.5 no computer
how to root android 2.3.5 without computer
how to root droid x2 2.3.5 without computer
root 2.3.5 without computer
root android 2.3.5 without pc
root droid x2 2.3.5 no computer
root droid x2 without computer
