Help with themes/roms
This is a discussion on Help with themes/roms within the Droid X2 Hacks forums, part of the Droid X2 Forum category; I was recently rooted my X2 running 2.3.4 and was needing some help getting a custom ROM or a theme setup. Sent from my DROID ...
Thread: Help with themes/roms
    Points: 795, Level: 14
    Level completed: 95%, Points required for next Level: 5
    Overall activity: 0.8%
    mpierce's Avatar
    37414
    Points: 45,910, Level: 100
    DirtyDroid's Avatar
    28665
    Upstate,NY
    14,576
    384 times
    NP, what did you need help with as far as the theme or ROM?
    mpierce's Avatar
    37414
    Just how to go about installing one or setting one up. I've never done it before.
    Points: 961, Level: 16
    Level completed: 61%, Points required for next Level: 39
    lhkjohn's Avatar
    44204
    Jul 2011
    OC
    82
    This is a really good all in one thread for getting everything you need.
    But basically, install system recovery from link, download ROM from one of the links and place it on your sd card... Run and install system recovery, then from recovery install zip from sd card and navigate to the ROM zip file and install zip. After that's done make sure you clear data/cache/Davlik and then reboot all from recovery. Voila!
    http://forum.xda-developers.com/show....php?t=1313103
    -Tapatalkin' from my Liberty'd DROIDX2
  1. New to roms and themes
    By xaalfx in forum Droid X2 ROMS
    Last Post: 09-18-2011, 10:36 PM
  2. Themes/Roms
    By Sean Wristen in forum Droid X Help
    Last Post: 01-13-2011, 04:26 PM
  3. OTA 2.340 - What Roms/Themes Available
    By Ro6d33zy in forum Droid X ROMs
    Last Post: 12-20-2010, 12:15 AM
  4. ROMs, Themes, Etc
    By Karem in forum Droid X Hacks
    Last Post: 12-05-2010, 07:29 PM
  5. Themes and Roms
    By simon_sez in forum Droid X Themes
    Last Post: 11-24-2010, 06:11 PM
how to change theme on droid x2
how to change theme on rooted droid x2
how to install a theme on rooted droid x
how to install custom themes on droid x
how to put a theme on a droid x2
how to use themes on droid x2
how top put themes on droid x
install custom themes on rooted droid x2
install theme droidx2
installing theme for rooted droid x2
