problem with installing Atrix
This is a discussion on problem with installing Atrix within the Droid X2 Hacks forums, part of the Droid X2 Forum category; I have rooted my phone and went to download the atrix files. I did download the right files atrix, 0.1 and 0.1-0.2 and 0.2-0.3. After ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Like Tree4Likes
Thread: problem with installing Atrix
    Points: 774, Level: 14
    Level completed: 74%, Points required for next Level: 26
    Chiknhawk's Avatar
    41378
    22
    I have rooted my phone and went to download the atrix files. I did download the right files atrix, 0.1 and 0.1-0.2 and 0.2-0.3. After downloading I open the files using Winrar and it showed me 3 folders (data, META-INF, system).So I connected my phone to PC and copy and pasted these files to my internal SD under download section. Then I went to recovery mode and I wiped data,cache, then went to my download folders and I didnt see any nameless-series_stock file. I just see the exact same file I copy and pasted from my PC which is data, META-INF, system. Was there some special way I had to get these Atrix files to my phone to flash ROM?? Im a noob at this. Please help
    Themer
    Points: 6,277, Level: 51
    Level completed: 64%, Points required for next Level: 73
    Overall activity: 2.5%
    victimssun's Avatar
    44999
    Aug 2011
    Harrisburg, PA
    539
    15 times
    You'll want to copy the entire .zip file to your sd card. Then run recovery, install .zip from sdcard, navigate to the .zip and install. Then do the same for the patches
    Points: 9,019, Level: 63
    Level completed: 90%, Points required for next Level: 31
    firefighterguy's Avatar
    8489
    Colorado
    1,559
    46 times
    Adding a little just incase, you won't be able to flash the rom in stock recovery - the one that is native on the phone. You will need the custom recovery, if you don't already have it. If you search the forums, you will find the X2 bootstrap (the custom recovery). Once you have it installed, plug your phone in and run the app and select "install recovery." Then after it gives you the success popup, select "recovery mode." And you should be able to flash it from there. When you do flash it, do it all over again (it has the custom recovery built into the rom so you won't have to reinstall the app.) Because when you factory reset, you will loose the recovery mode. But when you install the revovery mode and select recogery mode again with your phone plugged in, select the option to reboot. And after that, as long as you don't select battery mode or do a data wipe, you will be able to boot into bootsrap whenever you have the phone plugged into the charger.
    Flashing a rom is as simple as what the above poster said. You don't need WinRAR or anything. Nor will you have to do anything else other than to select install zip from bootstrap. :-)
    ____________________
    "King of the Self-Edit'"
    "Patriotism is supporting your Country at all times. And your government only when it deserves it" --Mark Twain
    Are we really Free? How "Free" do you think we are when we are not allowed to do anything without potentially being in violation of *something. *
    Chiknhawk likes this.
    "King Of The 'Self-Edit'"
    Chiknhawk's Avatar
    41378
    22
    OK, so I figured out what I was doing wrong. Rather than leaving the .zip as is before putting it in SD card, I unzipped it before putting it in the SD card. Now my next question is, while I am installing the 3 files from system recovery, what do I do after installing the first file? Do I reboot the phone and let it restart, then open recovery again and than I install second file then restart?? Or do I just install all 3 then reboot?? And one more question is before I install first file, I should clear cache and Davlik cache, but what about system data?? Do I clear system data too before I start installing the first Atrix file??
    Themer
    victimssun's Avatar
    44999
    Aug 2011
    Harrisburg, PA
    539
    15 times
    I'm not 100% sure if it matters, but for safety reasons, you could just install atrix, restart, enter recovery, install patch, restart, enter recovery, install patch. That's how I'd handle it.
    You want to clear all three, cache, Dalvik, and system data.
    8489
    Colorado
    1,559
    46 times
    Quote Originally Posted by Chiknhawk View Post
    Shouldn't have to reboot at all between zip installs. As long as you clear your dalvik cache, cache patitions and clear data before flashing your first zip, you should be fine. I flashed .1 then .1-.2 then ..2-.3. Without a hitch. I also downloaded the full .2 and flashed .2-.3 without a hitch too. But like I said, be sure to clear dalvik and the other cache partition, and clear data in bootstrap first.
    Themer
    victimssun's Avatar
    44999
    Aug 2011
    Harrisburg, PA
    539
    15 times
    I'd listen to him ^ . haha, I just installed .2. Then a couple days later realized there was .2 > .3.
    Chiknhawk's Avatar
    41378
    22
    thanks guys for the quick responce. I have just installed it, and will see how it handles next few days.
    8489
    Colorado
    1,559
    46 times
    Sweet! Good to hear. Just to letcha in on a little secret too, give it a couple or a few days to "break in" or "settle." And then see how its going. ROM's usually have a breakin period - like when you buy a new car or new shoes/boots.
    Themer
    victimssun's Avatar
    44999
    Aug 2011
    Harrisburg, PA
    539
    15 times
    Quote Originally Posted by firefighterguy View Post
    Seee.. this is helpful. This was my first rom. I flashed it, flashed back to my backup, then immediately went back again thinking I should give it a second chance (all within an hour). I had a phone identity crisis. But now, I've got it all setup just right, loving it!
  1. How to get atrix rom on x2
    By dechristimo in forum Droid X2 ROMS
    Last Post: 10-02-2011, 12:18 AM
  2. Now that im running atrix rom....
    By lpmboss in forum Droid X2 ROMS
    Last Post: 09-29-2011, 11:39 PM
  3. Replies: 7
    Last Post: 08-05-2011, 02:10 PM
  4. Problem installing Liberty ROM
    By FireHazard in forum Droid X ROMs
    Last Post: 05-26-2011, 07:53 PM
  5. Problem installing Incognito theme on Rubix Focused
    By DroidTech in forum Droid X Themes
    Last Post: 10-24-2010, 12:54 AM
(error 0) atrix rom
atrix 2 ota update error status 7
atrix recovery mode status 7
droid x2 internal and external sdcard mixed up
find chiknhawk
motorola atrix bootstrap recovery
motorola atrix ota update error status7
motorola atrix status 7
status 7 error when installing rom droid x
where to download the atrix rom fot droid x2
