Battery calibration (New method?)
This is a discussion on Battery calibration (New method?) within the Droid X2 Hacks forums, part of the Droid X2 Forum category; Lately I've noticed my battery% was only going to 95% at a full charge and no higher, despite wiping battery stats multiple times I couldn't ...
Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 41
Like Tree2Likes
Thread: Battery calibration (New method?)
    Points: 10,859, Level: 69
    Level completed: 3%, Points required for next Level: 391
    Overall activity: 65.3%
    juhde's Avatar
    38196
    New Mexico
    1,716
    57 times
    Lately I've noticed my battery% was only going to 95% at a full charge and no higher, despite wiping battery stats multiple times I couldn't seem to find a way to get it fully charged.
    Well my friends I finally found the answer.
    First charge until Android says your battery is full and to unplug your device.
    Next unplug and power down the X2.
    From a powered off state, plug in to the wall charger. This should boot the phone into charge mode, you should see a large battery icon and it should say that it's 100% and have a check mark.
    Once you're at this point, leaving the X2 plugged in, remove the battery door and the battery. The X2 should reboot once again into charge mode, but this time the large battery icon should be empty and a question mark in the middle of it.
    Now reinsert the battery and reattach the battery door, the onscreen icon should change to 5%, leave it plugged in and charging until it reads 100%. It should only take about 10 minutes. Now press and hold the power button until the phone starts to boot up.
    If you're not rooted unplug the phone and then your work is done, treat yourself to a popsicle for a job well done. However, rooted users may choose to perform an additional step. If so continue reading.
    Once it's finished booting use System Recovery to boot into custom recovery and wipe battery stats. You'll find this option under Advanced. After doing so, go back to the main menu, unplug and choose reboot into Android. Now go get one of those popsicles those non root types are already enjoying.
    Hope this has helped someone.
    Cheers!
    Sent from my Android device.
    Points: 41,310, Level: 100
    Overall activity: 99.9%
    Activity Award
    DirtyDroid's Avatar
    28665
    Upstate,NY
    13,640
    162 times
    Nice find and write up..ill have to share this with my friend with the x2...wevwere just talking about it the day
    Points: 15,964, Level: 81
    Level completed: 23%, Points required for next Level: 386
    Overall activity: 76.4%
    BHuber09's Avatar
    34670
    Atlantis
    5,542
    136 times
    I do this all the timr!! I literally swear by it
    FreeMyMoto!!!
    FreeMyMoto!!!
    If you need help PM me!!!
    Points: 45,915, Level: 100
    Posting Award
    macpro88's Avatar
    20491
    6,966
    322 times
    Nice find, had this happen to me on my X a few weeks ago, can't remember what I did, but I got it fixed, something similar to your method. I was on CM7 as well and thought maybe a CM7 issue.
    DroidXForums Guidelines of Conduct
    Show Your Support and Become a Supporting Member Today!
    RS Team Leader
    Points: 21,495, Level: 92
    Level completed: 15%, Points required for next Level: 855
    Overall activity: 20.5%
    popcenator's Avatar
    21238
    Omaha, NE
    8,208
    132 times
    Yay for popsicles!
    juhde's Avatar
    38196
    New Mexico
    1,716
    57 times
    Quote Originally Posted by popcenator View Post
    Yay for popsicles!
    Indeed
    Points: 4,977, Level: 45
    Level completed: 14%, Points required for next Level: 173
    Overall activity: 1.0%
    gunner1982's Avatar
    25150
    ohio
    1,095
    19 times
    Yay for popsicles!
    +1
    Points: 355, Level: 7
    Level completed: 10%, Points required for next Level: 45
    kifey's Avatar
    45467
    Aug 2011
    Western New York
    17
    Worked petty good. I turned phone off and waited for the 100% and check then pulled battery. Once it reset to the question mark I reinserted battery. It started at 20% then jumped to 60% then charged as normal to 100 does that actually calibrate battery?
    juhde's Avatar
    38196
    New Mexico
    1,716
    57 times
    Quote Originally Posted by kifey View Post
    If you're rooted yes, if not rooted it will only ensure you have a full charge.
    kifey's Avatar
    45467
    Aug 2011
    Western New York
    17
    Well I just got root on .602. Just got clockwork recovery installed. Im new to this. Only have had my x for a bit over a month courtesy of ebay. Im gonna see what I can get myself into then out of
  1. Battery calibration
    By Missouriexile in forum Droid X General Discussion
    Last Post: 07-28-2011, 03:17 PM
  2. Battery Calibration app
    By johnnysyeah in forum Droid X Apps
    Last Post: 07-13-2011, 11:40 PM
  3. battery calibration with GB
    By heartlandex in forum Droid X General Discussion
    Last Post: 04-24-2011, 02:14 AM
  4. Battery Calibration App!
    By wicked in forum Droid X Apps
    Last Post: 04-15-2011, 08:16 PM
  5. Calibration of battery
    By Dustin0308 in forum Droid X Help
    Last Post: 03-03-2011, 08:38 PM
battery calibration droid x2
calibrate battery droid x2
calibrate droid x2 battery
droid x battery calibration
droid x calibrate battery
droid x2 battery calibration
droid x2 battery reset
droid x2 calibrate battery
how to calibrate droid x2 battery
how to reset droid x2 battery
