Battery calibration (New method?)
This is a discussion on Battery calibration (New method?) within the Droid X2 Hacks forums, part of the Droid X2 Forum category; Great. Just remember to install the patched BSR once you are on CM9 and backups are your friend. Ideally you should make a backup before ...
Page 5 of 5 FirstFirst ... 345
Results 41 to 41 of 41
Like Tree3Likes
Thread: Battery calibration (New method?)
  1. #41
    Points: 28,773, Level: 99
    Level completed: 26%, Points required for next Level: 1,227
    Overall activity: 7.4%
    7,093
    338 times
    Great. Just remember to install the patched BSR once you are on CM9 and backups are your friend. Ideally you should make a backup before and after any major changes to your phone. Just note that backups take up a lot of space so you will have to manually keep track of them and delete the obsolete ones.
  1. Battery calibration
    By Missouriexile in forum Droid X General Discussion
    Last Post: 07-28-2011, 03:17 PM
  2. Battery Calibration app
    By johnnysyeah in forum Droid X Apps
    Last Post: 07-13-2011, 11:40 PM
  3. battery calibration with GB
    By heartlandex in forum Droid X General Discussion
    Last Post: 04-24-2011, 02:14 AM
  4. Battery Calibration App!
    By wicked in forum Droid X Apps
    Last Post: 04-15-2011, 08:16 PM
  5. Calibration of battery
    By Dustin0308 in forum Droid X Help
    Last Post: 03-03-2011, 08:38 PM
calibrate battery droid x2
calibrate droid x2 battery
droid x2 battery calibration
droid x2 battery problems
droid x2 battery reset
droid x2 calibrate battery
droid x2 reset battery
how to calibrate droid x2 battery
how to reset droid x2 battery
