Lag and Redraw Problems?
This is a discussion on Lag and Redraw Problems? within the Droid X2 Hacks forums, part of the Droid X2 Forum category; Are you so tired of the constant redraw problems with third party launchers? Redraws you ask what's that? You bring your phone out of sleep ...
Page 1 of 17 12311 ... LastLast
Results 1 to 10 of 170
Like Tree4Likes
Thread: Lag and Redraw Problems?
    Points: 42,333, Level: 100
    psychotic_penguin's Avatar
    5117
    Rapid City, SD
    5,088
    243 times
    Are you so tired of the constant redraw problems with third party launchers? Redraws you ask what's that? You bring your phone out of sleep and the home screen just freezes and the launcher restarts, then you have the 5-10 second lag where nothing works......this is a redraw. Also of note, do you have lag swiping from screen to screen or opening an app or the app drawer? Do you feel like tossing your phone out the nearest window or throw it against a wall?
    There's hope and something that'll last us until either a dev starts working on a ROM or Gingerbread drops.
    The process requires your phone to be rooted and the use of a couple of free apps from the Market and the Supercharger script
    I found this on the mothership [Script] V6 SuperCharger !! HTK & BulletProof Launchers! FIX MEMORY FOR ALL ANDROIDS! - Droid Forum - Verizon Droid & the Motorola Droid Forum
    Before even considering this make sure you read it over
    , and then to be sure read it over again. There's a lot of info that most of which will boggle a new user, but to break it down to easy terms:
    Requirements:
    1. Rooted Phone
    2. Script Manager (now Automatically Interactive!) or Terminal Emulator to run the script.
    Installing/Using:
    1. Download the attached V6_SuperCharger_for_Android.zip and extract the script to your sdcard.
    ... Do NOT run the V6 SuperCharger install script at boot!
    2. Load the script (V6_SuperCharger_for_Android.sh) into Script Manager and select "Run as Root."
    3. Touch the screen for the soft keyboard or slide out the keyboard and get SuperCharged!
    I chose option 6 (Balanced 2) and haven't had a redraw since. All credit goes to zeppelinrox this is his work and will work on most Android devices.
    Points: 9,019, Level: 63
    Level completed: 90%, Points required for next Level: 31
    Overall activity: 2.5%
    firefighterguy's Avatar
    8489
    Colorado
    1,559
    46 times
    Thank you for the info, Sir! I will read it over 60 times and then try it out. I can't wait to see how this turns out...
    "King Of The 'Self-Edit'"
    5117
    Rapid City, SD
    5,088
    243 times
    It made my phone 100% better right away, I'm not gonna mess with any of the other settings until an SBF is available just to be safe.
    8489
    Colorado
    1,559
    46 times
    Which do you think is better? Term Emulator? Or Script Manager? I can easily do Term Emulator especially if I know what to type. Lile when I reeoted my X1 via the term emulator because I got bored. Lol
    5117
    Rapid City, SD
    5,088
    243 times
    I used Script Manager much easier since you click on the script on the SD Card and don't have to type it in as you do on Terminal Emulator
    Tagger Second Class
    dcdevito's Avatar
    39483
    Hudson Valley, NY
    15
    Has this worked on the DX or DX2?
    8489
    Colorado
    1,559
    46 times
    Its working like a charm on my DX2
    "Patriotism is supporting your Country at all times. And your government only when it deserves it" --Mark Twain
    5117
    Rapid City, SD
    5,088
    243 times
    This will work for any Android phone...it's made the X2 run a lot better
    Ok so I did this and its working but does the default back to stock after a reboot? Will I have to do the script every time
    Rescue Squad
    Points: 28,311, Level: 98
    Level completed: 97%, Points required for next Level: 39
    Leach19m's Avatar
    31277
    Washington
    7,053
    234 times
    Quote Originally Posted by magicriggs View Post
    No, its a permanent change until you undo it manually
    Sent from my Droid X, which Netflix thinks is an HTC Vision!
  1. Anyone having problems with Go Sms on GB?
    By xLaura13x in forum Gingerbread General Discussion
    Last Post: 06-07-2011, 09:42 AM
  2. ADWEx redraw problem
    By drewlamo1 in forum Gingerbread General Discussion
    Last Post: 06-01-2011, 12:40 PM
  3. Replies: 0
    Last Post: 11-02-2010, 09:36 AM
  4. mp3 problems
    By forsaken in forum Droid X Help
    Last Post: 10-03-2010, 10:16 PM
  5. A few problems
    By phils514 in forum Droid X Help
    Last Post: 08-04-2010, 08:01 PM
droid x redraw
droid x screen lag
droid x2 home screen lag
droid x2 lag
droid x2 lagging
droid x2 laggy
droid x2 redraw
droid x2 screen lag
nitro lag nullifier
redraw problem
