When I run the 3G script it says #Backing up ORIGINAL build.prop...
I do not ever get anything else after that saying it has completed. If I back out and go into /system I do see the new build.prop and the old build.prop was renamed to build.prop.un3g.
Is this normal behavior or did I do something wrong? I am running off of wifi now cause I'm in my office where the 3G signal is extremely weak so I cannot test.
Edit: Just went outside and ran a test using speedtest.net app. Without Zepps 3G script my average download speeds were 1412 kbps, upload was 885 kbps.
Using Zepps 3G script my download speeds were 2072 kbps and upload speeds were 909 kbps.
These were the averages of 6 tests each, good amount of difference in the download speeds not much of a difference in upload speeds. Still not sure if I did everything I was supposed to when I ran the script since I was never notified the script was done doing its thing.
4Likes
