How to make Stock X2 launcher smooth
This is a discussion on How to make Stock X2 launcher smooth within the Droid X2 General Discussion forums, part of the Droid X2 Forum category; Hey guys..ever since the gingerbread update my stock launcher has been kind of laggy. Sometimes it's just plain unacceptable. I liked it better on froyo ...
Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By GoCliffGo05
  • 1 Post By NUNsLAUGHTER92
Thread: How to make Stock X2 launcher smooth
    Points: 552, Level: 11
    Level completed: 4%, Points required for next Level: 48
    Overall activity: 1.8%
    250 Experience Points100 Experience Points31 days registered7 days registeredTagger Second Class
    austinslater's Avatar
    62975
    Nov 2012
    24
    Hey guys..ever since the gingerbread update my stock launcher has been kind of laggy. Sometimes it's just plain unacceptable. I liked it better on froyo but I can't factory reset or revert to froyo or anything because I'm flashed. Seems the only thing that has improved is the battery life. Also..will the X2 be getting ICS?? Thanks in advance.
    Points: 27,254, Level: 97
    Level completed: 91%, Points required for next Level: 96
    Overall activity: 29.9%
    7,093
    338 times
    X2 will not be getting ICS. It is dead as far as Moto/Verizon are concerned. Its received its last update.
    A couple things to try here. 1. Turn the phone off. Hold volume down and then hold power. Release when "fastboot" appears at the top of the screen. Press volume down 7 times until it says "android recovery." Press volume up once. At the next ! Screen press volume up and volume down once at the same time. You are now in stock recovery. Scroll with volume to "wipe cache partition" and press power to execute. Then reboot.
    Or 2.) Download another launcher from Google play.
    62975
    Nov 2012
    24
    Thanks for the reply. Do you know if doing the first option could mess with my phone being flashed to a different carrier?
    Points: 3,516, Level: 37
    Level completed: 11%, Points required for next Level: 134
    Overall activity: 3.5%
    NUNsLAUGHTER92's Avatar
    38861
    Las Vegas, NV
    464
    8 times
    Quote Originally Posted by austinslater View Post
    It won't mess it up. Just don't downgrade radios and you'll be good.
    Edit: And you can factory reset. The only thing it could mess up is MMS. You'd need to put the correct APNs on if you wipe data.
    "You know, a long time ago being crazy meant something. Nowadays everybody's crazy."
    austinslater likes this.
    62975
    Nov 2012
    24
    Quote Originally Posted by NUNsLAUGHTER92 View Post
    I did this and it is faster..but now none of my live wallpapers will work. They just keep force closing. Any idea what's going on??
    62975
    Nov 2012
    24
    Nevermind! They started working again. Thanks for all your help!
  1. How do i make my phone go back to stock from gingerbread?
    By NickYate in forum Gingerbread General Discussion
    Last Post: 09-04-2011, 12:19 PM
  2. did GB make it possible to diable the stock music player???
    By renthorin in forum Gingerbread General Discussion
    Last Post: 06-01-2011, 12:08 PM
  3. So which launcher runs better on the new stock GB .596? Launcher Pro or ADW?
    By cclauss777 in forum Gingerbread General Discussion
    Last Post: 05-31-2011, 07:05 PM
  4. How to LPP as stock launcher
    By frogrm7 in forum Droid X Hacks
    Last Post: 10-06-2010, 12:48 AM
  5. Help me/ How do i make my Droid x run Smooth
    By Gilray in forum Droid X Help
    Last Post: 08-07-2010, 06:37 PM
cloud x2launcher downloads
droid moto x2 launcher
how to make launcher smoother
smooth launcher
smoothest launcher for droid x
stock launcher appears from time to time
stock launcher laggy driid x2
stock launcher sommth
what is the factory launcher for the droid x2
x2 launcher
