Droid X2 charging problem
This is a discussion on Droid X2 charging problem within the Droid X2 General Discussion forums, part of the Droid X2 Forum category; Recently on my droid x2 it has been acting up while charging. I plug the charger into the micro usb port and it will not ...
Results 1 to 8 of 8
Thread: Droid X2 charging problem
    Recently on my droid x2 it has been acting up while charging. I plug the charger into the micro usb port and it will not charge. It will if its in this wierd position in there. An thats only sometimes. Would a new cable work? Or is it the connections in the micro usb port. If that would verizon replace those? Or would they be all "tough luck".
    Points: 26,735, Level: 97
    Level completed: 39%, Points required for next Level: 615
    Overall activity: 30.9%
    7,093
    338 times
    Could be a cable. However if you have to move the plug in all kind of weird positions to get it to charge then I would guess it's a problem with the port on your phone. Do you have any kind of insurance on it?
    Edit: you could always take apart your phone and have a look in there to see if it is broken or twisted or if something is missing that should be holding it in place. There are guides all over the Internet.
    Points: 12,927, Level: 74
    Level completed: 20%, Points required for next Level: 323
    Overall activity: 7.5%
    DroidXFanatic's Avatar
    52093
    Nov 2011
    1,103
    42 times
    I'm having this exact problem. Just started like a week ago. I kinda gotta get in there & move it to the correct spot & not touch it for it to charge & make connection. I have a feeling its not the charger like gocliffgo said but the actual charging port on phone. Starting to think the wear & tear of having this phone for almost 2 years is finally catching up to it. Its just about time to upgrade my X sadly.
    Liberty 3V2.0 - Droid X
    I have like the when you get the phone you get the 1 year support thing. They don't even make Droid x2's anymore. Would they still replace it?
    Sent from my MB870 using Droid X Forums
    7,093
    338 times
    If you had insurance they would probably send you an X2 if they still have one laying around. If not they would bump you up the next "similar" device. It wouldn't be much better most likely.
    I know they replace internal problems. Would this count as one? I never dropped it on the port (I don't think you can even do that)
    7,093
    338 times
    Hmm I don't know if they would take the time to fix your phone or just send you a new one... It's a possibility they would fix it if you ask them to. And I'm thinking you wouldn't have had to drop it to damage it. Repeated plugging and unplugging could have just jarred something loose.
    Points: 335, Level: 6
    Level completed: 70%, Points required for next Level: 15
    250 Experience Points31 days registered7 days registered100 Experience Points
    DroidJoker's Avatar
    62020
    Oct 2012
    39
    I had the same problem, before you send your phone in try other chargers. Some may even make your screen lock up while it charges. I have noticed that before the actual usb port goes bad the cables will.
    Droid X2
    Eclipse 2.3
  1. Charging problem
    By Sefirosu in forum Gingerbread Help
    Last Post: 06-05-2011, 04:29 PM
  2. Dx charging problem
    By billyg17 in forum Droid X General Discussion
    Last Post: 01-31-2011, 10:42 AM
  3. Replies: 3
    Last Post: 12-05-2010, 05:37 PM
  4. Charging my Droid X
    By lithiasales.js in forum Droid X Hacks
    Last Post: 09-24-2010, 03:19 AM
  5. Replies: 0
    Last Post: 08-09-2010, 06:59 PM
droid charging problems
droid x2 charger port
droid x2 charger problems
droid x2 charging issues
droid x2 charging problem
droid x2 charging problems
droid x2 not charging
droid x2 problems
droid x2 wont charge
motorola droid x2 charging problems
