Strange, never had that issue. What's your phone setup?
This is a discussion on Launchers within the Droid X2 General Discussion forums, part of the Droid X2 Forum category; Strange, never had that issue. What's your phone setup? Sent from my DROID X2 using Droid X Forums...
What do you mean? I'm losing connect and my text messages are messing up too.
I mean are you rooted, rom'd or on stock. Also does this problem still happen without go launcher installed.
I'm not rooted. No it doesn't happen without a launcher installed.
That's really weird, i haven't really heard of this happening. If it stops when you uninstall the launcher then I have to say its the launcher for some reason. You could try and contact the developers. In the mean time just to give something a shot try wiping your phone cache.
1. Power down your phone
2. Push and hold volume down then power until "fastboot" appears at the top of your screen.
3. Push volume down 7 times to highlight "Android Recovery" and push volume up to select it.
4. Push volume up and volume down at the same time to access the recovery menu.
5. Highlight wipe cache partition and press power to execute.
6. Reboot.
Will this erase everything off my phone? I don't wanna lose all my stuff.
No cache won't touch anything on your phone. Just don't wipe data, only cache.
