Apex isn't compatible with the Droid x2?
This is a discussion on Launchers within the Droid X2 General Discussion forums, part of the Droid X2 Forum category; Apex isn't compatible with the Droid x2? Sent from my DROID X2 using Droid X Forums...
What is ics
Ics is short for the operating system. Ice cream sandwich
Jb short for jelly bean
Gb short for gingerbread and so on
****Mays galaxy 3****
Apex is only compatible with Ics.
Does the phone have to be rooted?
don't have to be rooted to use apex but in order to run Ics on the dx then yes you need to be rooted.
Holo is a good one also. It was added to the vxl rom. Here it is but I don't use it so its not set up.
What rom do I run today??
1kds SBF http://www.droidxforums.com/forum/dr...-problems.html
If you are in a state of "OMG I jacked my phone up". Go here for help.http://www.droidxforums.com/forum/droid-x-rescue-squad/
Yup. Like pop said. I use home manager (free In Play store) to bounce between launchers. It gives you the option to kill the ones you don't use. Keeps them from running in back ground. At one time I had 5 different launchers installed.
Im using Zeam launcher & its working pretty good for me. Not too much customization but its simple, clean & fast.
Sent from my DROIDX
I've changed to the go launcher now. Does anyone else have an issue with losing connection or service?
