Hey, I have eclipse installed and in doing so it automatically switched my sd card location. Internal is now external, and external is now internal. under settings I have selected install apps.to internal sd card, which now means they are installing to my external card correct? Also when I got into settings to manage applications it shows hardly anything installed to the external card but that's because its.flipped right? Im just a little confused cuz if I ever want to sbf again I want to make sure they are installed to the real external card so I don't lose anything. So theoretically I should not use the option under settings to "move app to external card" because I would be moving it to the internal? Is there any other way to see if they are installed on my real external card? For example plugging in to a computer via usb and being.able to see what's there?
1Likes
