Bricked droid x2, need help!!!
This is a discussion on Bricked droid x2, need help!!! within the Droid X2 General Discussion forums, part of the Droid X2 Forum category; My droid x2 is bricked as in it wont start up. All this happened after trying to install a new rom, It went into a ...
Results 1 to 7 of 7
Thread: Bricked droid x2, need help!!!
    My droid x2 is bricked as in it wont start up. All this happened after trying to install a new rom, It went into a bootloop then tried to fix that by going into android recovery but then that didnt work. Then finally the battery stopped charging
    Points: 3,473, Level: 36
    Level completed: 82%, Points required for next Level: 27
    Overall activity: 31.4%
    adamwhitehead's Avatar
    49777
    Oct 2011
    russellville, al
    282
    Quote Originally Posted by CristianWasHere View Post
    You'll need to find a friend that has an x or x2 to charge your battery, once that's done you need to sbf in rsdlite
    Points: 2,100, Level: 27
    Level completed: 67%, Points required for next Level: 50
    Overall activity: 3.0%
    l3l4ck0ut's Avatar
    51551
    Nov 2011
    183
    Tryto find a friend wit a droid x2 or x with a charged battery..n put in urs. Then go into recovery n wipe data. Wipe cache if u can. Reboot. If still the same.. Then.. Power on while pushing up volume n SBF it.. Using rsd lite..Thas wat id try.. Wont hurt at least.
    Sent from my rooted n ROM'ed Droid X2 using Droid X Forums
    Sent from my rooted n ROM'd Droid X2 using Droid X Forums
    l3l4ck0ut's Avatar
    51551
    Nov 2011
    183
    I was typing as u said that lol
    Well I have the sbf and rsdlite v5.3.1 I guess all I need is the battery, could I just order a new one as well or something
    49777
    Oct 2011
    russellville, al
    282
    I think factory battery's are only charged to 70% or so and its highly recommended to be at 100% on an sbf cause they take time... Verizon should be more than happy to charge your battery though.
    Points: 17,835, Level: 84
    Level completed: 97%, Points required for next Level: 15
    Overall activity: 1.6%
    juhde's Avatar
    38196
    New Mexico
    1,717
    59 times
    You can sbf with out a battery at all if you buy a team black hat factory cable. Unfortunately that's about all they're good for. But when you need it you'll be glad it's there.
    Another option is to take the battery to a Verizon store. They should charge it for you, if it's a corporate store they definitely will.
    Sent from my Android device.
  1. Bricked droid x, please help.
    By Ntnme2lose in forum Droid X Rescue Squad
    Last Post: 08-05-2011, 07:26 PM
  2. Need some serious help with a bricked Droid X
    By braekdown in forum Droid X Rescue Squad
    Last Post: 06-12-2011, 08:49 AM
  3. Droid X bricked a little help?!
    By Danman96 in forum Droid X Rescue Squad
    Last Post: 05-10-2011, 09:59 PM
  4. Bricked My Droid X
    By StR82Sn0W in forum Droid X Rooted Issues
    Last Post: 03-19-2011, 07:06 AM
  5. Bricked my Droid X the other day.
    By Eleigh in forum Droid X Help
    Last Post: 02-14-2011, 02:28 AM
bricked droid x 2
bricked droid x2
bricked droid x2 fix
droid x2 brick fix
droid x2 bricked
droid x2 wont boot
fix brick droid x2
fix bricked droid x2
how to fix a bricked droid x2
how to fix bricked droid x2
