oN MY DROID X IF I AM DOWNLOADING AN APP AND PLAYING A GAME THE PHONE GETS HOT FROM NOT HAVING AN ACTIVE COOLING FAN. DOES THE DROID X2 GET AS HOT WITH THE DOUBLE CORE OR IS IT ABOUT THE SAME?
This is a discussion on Droid x and droid x2 processor getting hot? within the Droid X2 General Discussion forums, part of the Droid X2 Forum category; oN MY DROID X IF I AM DOWNLOADING AN APP AND PLAYING A GAME THE PHONE GETS HOT FROM NOT HAVING AN ACTIVE COOLING FAN. ...
Not sure about the x2 but the x1 will shut down if it gets too hot I would assume the x2 would so the same.
Sent from Mopar-x
I have had my X2 nearly a week and it seems to get a little bit hotter than my X while using and charging together in the car mount.
I HAVE CAPS LOCK TOO!!
I believe its about the same though.
Droid X Running CM7
Just scored 3210 in quadrant!
Anything over 120°f and it will likely go to cool down mode. So don't worry about it
Thanks you guys! So if i am not going to be doing alot of gamingand stuff the X2 would really not be a good upgrade?
My X2 is always running around 110, it rarely goes below 105.
How to root your phone
How to SBF an X2
How to SBF an X
Guidelines of Conduct
iPhone - You're holding it wrong
