***What I did to solve wallpaper cropping issue***
This is a discussion on ***What I did to solve wallpaper cropping issue*** within the Droid X Wallpapers forums, part of the Droid X Extras category; I figured out that you cannot just download a standard size wallpaper that is 480 x 854 and put the whole pic on your x ...
Results 1 to 7 of 7
  • 1 Post By Smoove7
Thread: ***What I did to solve wallpaper cropping issue***
    Smoove7's Avatar
    5831
    7
    I figured out that you cannot just download a standard size wallpaper that is 480 x 854 and put the whole pic on your x phone because the orange box will not fit around the whole pic.
    But why? Well the reason is that if you use a pic that is 960 x 854 then the droid likes that and you can put the orange box around the full image. I am sure there are other reasons.
    Let me also mention that this is for the phone in a vertical position with the on off button facing up. If you want to do this for horizontal position where the volume buttons are facing up, then you would need to do a little editing but the concept is the same from the instructions below.
    So if you are the type that wants your image to stay on one screen and not move but you also want to be able to see your full 480 x 854 image and not have the sides cut off by the phone then you do this:
    Get the app launcher pro and install. Here is a vid of launcher pro:
    Then Click menu >Preferences> appearance settings and Disable wallpaper scrolling.
    Then you have to have to trick the phone into still using the 960 x 854 pic but you center your 480 x 954 pic in the middle of that 960 x 854 template located here:
    http://img339.imageshack.us/img339/7...ndtemplate.jpg
    Just take your 480 x 954 pic and place in the white part and then save the full image with the black parts on both sides as a jpg. Then put that saved pic into your phone and set as background. Now you can crop the whole pic and your pic shows up in the center of the screen and it does not matter that the sides are cut off because the sides are blank anyway.
    There are probably better ways to do this but I thought I would try this.
    Points: 5,913, Level: 49
    stevewitt's Avatar
    2914
    Lake Station, In
    452
    18 times
    Quote Originally Posted by Smoove7 View Post
    Could you provide a bit more detail on how to use the template? TIA
    Droid X, Froyo, DarkSlide 4.2,
    Current Apps :Here
    Smoove7's Avatar
    5831
    7
    Well I personally use photoshop but you can do this in about any paint program. When you go to the link and see the template, right click and choose SAVE IMAGE AS and I save it to the desktop. Then I go into photoshop and open the template I saved. If you have a 480 x 854 pic that you want to use put that pic into the paint program as well. Then I move the actual picture over on top of the template and move it into place so that the white part is not showing. Your pic must be 480 x 854 to completely cover the white part. Once you have done that, save that complete image as jpg file. So you will have your pic and a black bar on each side of the picture. And there is your picture that you are going to put into the phone and set as your wallpaper. Put the orange box into the upper left hand corner of that pic once you have chosen to use it as your background and the orange box pops up. Then with the orange box in the upper left hand corner, drag the box to the lower right corner covering the whole picture, even the sides that have black on them. Lastly click on save and there you go.
    stevewitt likes this.
    Points: 10,255, Level: 67
    Backnblack's Avatar
    26
    2,816
    139 times
    There is no issue when you use the correct size image.
    Only the Skilled Survive
    1. Never be unarmed.
    2. See Rule #1
    Smoove7's Avatar
    5831
    7
    ^^^^ Exactly. Unfortunately 480 x 854 is not the correct image size to be able to put the orange box around a full picture to use as your background, 960 x 854 is, and you just need to do a little editing to get the result you are looking for if all you have is 480 x 854.
    I do apologize if I am unsure but if there is a way to get that orange box to fully go around a 480 x 854 image then if would be useful to know that information.
    droidlicous's Avatar
    556
    58
    There isnt a way to get it around the 480 by 854 you got the right concept right off bat!!
    Abaddon's Avatar
    8321
    30
    I downloaded an app called "Wallpaper Maker". It's $1.00 in the market but I think it's worth it. It allows you to crop things vertically as well as horizontally. The best part is that it stores the cropped wallpapers you create (you can also delete) so that you can switch back and forth. There is also a free app called crop wallpaper, but if you power down the phone or restart launcherpro, the image becomes distorted. With Wallpaper Maker it seems to hold the image nicely. You don't even have to change your settings in launcherpro for the vertical wallpaper (unless you want to anyway).
    I'm about to get my frozen yogurt. Now what?
  1. AR Wallpaper?
    By hollywood in forum Droid X General Discussion
    Last Post: 08-31-2010, 03:44 PM
  2. What wallpaper are YOU going to use?
    By Jaxidian in forum Droid X Wallpapers
    Last Post: 08-28-2010, 11:03 PM
  3. Random reboots cropping up; way to log/ID the cause?
    By validoption in forum Droid X General Discussion
    Last Post: 08-23-2010, 06:38 PM
  4. New Wallpaper
    By JonTx311 in forum Droid X Wallpapers
    Last Post: 08-10-2010, 02:11 PM
  5. Does rooting solve the LED notification issue when screen is on?
    By jtdiddy in forum Droid X General Discussion
    Last Post: 07-26-2010, 01:57 PM
android wallpaper orange box wont fit the picture
android will not show complete background picture
droid x no cropping wallpaperpp
droid x wallpaper issue
droid x wallpaper maker
droid x wallpaper size in paint
how to make pictures fit on the background of motorola x
how to make whole picture show on wallpaper droid x
how to set full picture wallpaper on droid x2
template
