Liquid Battery Icon :-p
This is a discussion on Liquid Battery Icon :-p within the Droid X Themes forums, part of the Droid X Development category; Will post download later....
Results 1 to 10 of 20
Like Tree2Likes
Thread: Liquid Battery Icon :-p
    haledroid's Avatar
    1200
    Points: 2,491, Level: 30
    Level completed: 28%, Points required for next Level: 109
    truckrod's Avatar
    1670
    OHIO
    173
    12 times
    Rooted OClocked DROIDX Rootedthemed Bionic
    Points: 3,761, Level: 38
    Overall activity: 1.3%
    giantsfan91's Avatar
    6546
    New York
    175
    whats name of this? how do i put them? thanks.
    truckrod's Avatar
    1670
    OHIO
    173
    12 times
    Quote Originally Posted by giantsfan91 View Post
    Liquid action theme 4 battery. I have all the icons it was originally for motorola droid 1. I change them over on my framework for the droid x and works good. it is a little bit involved I can help you through this later after I get off work! Or you can search it changing framework-res
    6546
    New York
    175
    Quote Originally Posted by truckrod View Post
    yes please tell me how to do this. thanks.
    afangrywarrior's Avatar
    2794
    Ok... this was posted 6 days ago and you still haven't uploaded or posted anything more than the fact that you plan on posting something?
    Points: 46,436, Level: 100
    psychotic_penguin's Avatar
    5117
    Rapid City, SD
    5,088
    243 times
    This was one of my favorite mods on my D1
    Points: 82,727, Level: 100
    250 Experience PointsYour first Group31 days registered100 Experience Points7 days registered
    wicked's Avatar
    15645
    San Jose CA.
    5,245
    728 times
    truckrod's Avatar
    1670
    OHIO
    173
    12 times
    if you like to do this i take no resposobility
    you must have Astro and Root explorer
    be rooted and recovery with bootstrap
    1 Do a backup
    2 You need Astro and root explorer
    take no responsibility for this 3 In root explorer go to system/framework/framework-res .apk . long press on framework-res then permissions take a note of the rw/r checks then back out one long press and pick copy
    4 Now go to the root of your sdcard and paste that framework
    5 I go out of root exp and then to astro . in astro make a file! .framework ! Copy the framework-res.apk and place it in .framework This is needed as you are going to change the .apk to a zip and then you are going to extract the zip in this directory! the reason for the dot in front of the file name is for win extracted all the framework the icons will not show up in your gallery after the extracting! n trust me you don't want that . lots of deleting
    6 Now you will need a ROM or theme that has the framework/ icons you are looking for . you can make another folder with that them name! don't forget the dot. and find the framework -res.apk change it to a framework-res.zip ! extract it to this directory! then look for the res/ then drawable-hdpi! in this you will see all the icons !
    7 You will need to delete the origanal framework-res.zip as you extracted it . win it extracts it ! It makes a copy and keeps the main one . because you are going to make a another framework-res.zip and you don't want to mix the two up. so delete the one thats still zipped don't worry you have the stock one in place in system you will overwrite it later
    8 make sure you had all the correct icons you needed to overwrite . look at all the icons in / stat_sys_battery_0.png to stat_sys_battery_unknown.png there are also some that show up in jog_dial_arrow_long_left_green.png if the build has a 10% increments ! you can change almost any of the icons in this if all match up and none are missing from wifi to car dock to status_bar_background.png look at different themes and you can see the differences.
    9 Now in astro multi check and pic the icons you want . copy then go to your .framework folder go to res/drawable-hdpi paste then yes to all the overwrites and after that is done back out to the file where you see assets,META-INF,res,androidmanifest.xml,resources.arsc. pick all ! and zip them up . Now you have made a framework_res.zip
    10 Now change the zip to a .apk and yes! back out of astro
    11 Go to root explorer then sdcrad/.framework/framework-res.apk Copy the framework-res.apk back out then to system/framework make sure you are r/w at the top and the paste and yes overwrite then dont forget to long press change your permissions to User read write Group read Others read this is very important as it will bootloop your phone if not done .back out of root and reboot
    hope i covered all as i do this all the time and not have skip something hope all goes well and good luck
    giantsfan91 likes this.
    truckrod's Avatar
    1670
    OHIO
    173
    12 times
    CAP201012181239.jpgCAP201012181241.jpgHere are a few pics of what you will see in framework
  1. Liquid in middle of screen under normal use?
    By BlitzeDonX in forum Droid X General Discussion
    Last Post: 01-05-2011, 07:20 AM
  2. Changed battery icon but disappears while charging
    By mpetruzz in forum Droid X Themes
    Last Post: 12-01-2010, 10:07 PM
  3. Battery % Shown in Battery Icon in Status Bar
    By asctony in forum Droid X Apps
    Last Post: 11-24-2010, 06:17 PM
  4. Battery icon has a ? on it?
    By HarleyDad in forum Droid X General Discussion
    Last Post: 11-16-2010, 08:49 AM
  5. Battery icon issue
    By jbreezy in forum Droid X Help
    Last Post: 09-22-2010, 08:22 PM
android liquid battery meter
battery icon apk
battery icons 2.3.3
liquid battery apk
liquid battery icon
liquid battery icon android
liquid battery icon download
liquid battery icons
liquid battery theme tilt
liquid battery theme.apk
