Need help on a transparent Status bar, Custom theming.
This is a discussion on Need help on a transparent Status bar, Custom theming. within the Droid X Themes forums, part of the Droid X Development category; I am customizing a theme and could not find a way to make the status bar transparent. I changed the status bar background.png to make ...
Results 1 to 9 of 9
Thread: Need help on a transparent Status bar, Custom theming.
    killathrilla's Avatar
    10232
    165
    37 times
    Question Need help on a transparent Status bar, Custom theming.
    I changed the status bar background.png to make it transparent, after i unlock it its solid black, is there a image i am forgetting to edit?
    -Rooted
    --Deodexed
    ---Rubix 1.5.2 Blurry
    ----[Theme]Custom!
    10232
    165
    37 times
    I found out that launcher pro when not hiding the notification bar cuts the background under the notification bar, does anyone know a way to extend the background to under the notification bar?
    -Rooted
    --Deodexed
    ----[Theme]Custom!
    Points: 1,242, Level: 19
    Level completed: 43%, Points required for next Level: 58
    Snarkrifice's Avatar
    20127
    Unfortunately, it's not a graphic you have to edit... It's some core framework files, I believe. I ran into the same issue with DarkEdge on the Droid 1. LauncherPro actually moves the notification bar up the visible field, so the wallpaper extends automatically, and when the bar is reshown, if it is transparent, the wallpaper is then visible through it. The problem is that, by default, Android begins to draw the wallpaper beneath the bar. Trying to do otherwise for custom theming has produced problems all around. I wish you best of luck, because as far as I know, no one has yet figured this problem out. Numerous people would be grateful if you did...
    Points: 51,541, Level: 100
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    i believe theres a metamorph for the transparent bar. you can always ask how it was done. it was at another site..
    Last edited by smalltowngirl13; 11-28-2010 at 12:20 PM. Reason: PM poster for link, Link removed.
    10232
    165
    37 times
    I think Ive seen the metamorph post, would it keep my icons and just replace the status bar?
    -Rooted
    --Deodexed
    ----[Theme]Custom!
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    Yes, it will just replace the status bar. the icons should stay the same.
    Points: 972, Level: 16
    Level completed: 72%, Points required for next Level: 28
    JsinLegacy's Avatar
    6826
    18
    go to Xeudous section on DroidForums and use his transparency edit for Froyo... the problem is your system might not be set up to accept transparent images yet on the rom/theme you are using
    10232
    165
    37 times
    I got it figured out, some launcher programs crop the wallpaper, the ota home launcher keeps the wallpaper under the status bar while launcher pro crops it to the bottom of the status bar. ADW also has a setting to include the status bar or not. I was using launcher pro and that was the reason why the bar was always black.
    -Rooted
    --Deodexed
    ----[Theme]Custom!
    newdroidx's Avatar
    7138
    MI
    281
    9 times
    Id get the metamorph from droidpirate.com then use multi-live wallpaper. It stretches the wallpaper past the status bar, thus you can see ur wallpaper threw the status bar. Also with multi-live you can set each one of ur homescreens to a different picture, change the transitions, etc.
    My phone has been flashed more times than an old pervert at Mardi Gras!
    DROID X
  1. theming droid x..tragically lost..
    By jigglapuff in forum Hacking Help
    Last Post: 12-03-2010, 10:07 AM
  2. Transparent widget skins
    By behemoth in forum Droid X Apps
    Last Post: 11-19-2010, 09:24 AM
  3. [THEME] TransStatus! Transparent Status Bar
    By mattyboy1013 in forum Droid X Themes
    Last Post: 10-07-2010, 05:22 PM
  4. ADW - Custom Theming Question
    By slivvy in forum Droid X Themes
    Last Post: 10-02-2010, 01:40 AM
  5. Moving market apps to system and theming
    By 92sho16 in forum Droid X Hacks
    Last Post: 07-25-2010, 09:32 PM
android custom status bar
android transparent status bar
custom status bar android
customize android status bar
customize status bar android
go launcher transparent status bar
launcher pro transparent status bar
launcherpro transparent status bar
transparent status bar android
transparent status bar launcher pro
