DroidX STILL restarts after shutdown
Shutdown, and "cold",...the DX restarts itself. Sometimes within 20 minutes., sometimes within hours. Verizon says this is a "known issue" and will be fixed with the next OS update...which I have heard now for a long time. In the forum this is discussed, but no definitive solution. Verizon will replace the phone, but only with a DX (which won't reassure me).
Android version 2.3.3 System version 4.5.605.MB810
I've done factory resets frequently, with no success.
I have run the DX with no apps loaded... and this isn't the solution.
I suspect the answer to my problem is "tough luck"
01-23-2012 08:40 AM
There isn't an answer because it's a bug that hasn't been fixed and probably won't be fixed.
Really the only solutions would be one of the following:
*Root your phone and install a custom rom
* turn your phone off twice (not fun haha)
* put your phone into sleep mode instead of powering it off
That's really all that can be done unless Motorola sends out a patch/ update
If you think you have bricked your phone... do this.... stop look around say a few curse words then take a deep breath because you haven't
we can fix this haha
Originally Posted by
cory46
Hold your breath...
Sent from my DROIDX using Xparent Cyan Tapatalk
Thanks. I expected as much.
Mine still did it in Cm7, Liberty, and Vortex.
Mine did that only a few times, but my friend had her DROIDX do it alot, even while she was on an airplane, but now hers doesn't do it as much anymore
I had this issue until I took the .621 update. I'm not rooted, and prefer not to be
Droidlynn & X
