SBF for almost 2 weeks with no success. Help.
This is a discussion on SBF for almost 2 weeks with no success. Help. within the Droid X SBF forums, part of the Droid X Rescue Squad category; I have been trying to SBF for about 2 weeks now. I have 2 laptops I have tried with different setups. I have one laptop ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
Thread: SBF for almost 2 weeks with no success. Help.
    Points: 87, Level: 1
    Level completed: 74%, Points required for next Level: 13
    Overall activity: 2.4%
    kickin_it's Avatar
    62222
    Oct 2012
    18
    Question SBF for almost 2 weeks with no success. Help.
    I have been trying to SBF for about 2 weeks now. I have 2 laptops I have tried with different setups. I have one laptop running Win 7 and I have tried using RSD 4.8 and 5.6 using the .621 SBF because I did take the update and am running BootLoader 30.04. I then setup a Virtual Machine and was running Ubuntu on it and using the sbf_flash method. Everything completes with no errors but it will not come out of BootLoader. The issue with RSD in Win 7 is it states there was an error switching phone to BP pass through, this errors occurs in 4.8 and 5.6. I have a second laptop running Win XP SP 3, I have run 4.8 on it but get a different error about the phone not re-enumerating. I am stumped. I do not know what else to do, I have used OEM cable, I have tried different cables, I have tried different USB ports. I have just about exhausted my resources but I am yet to be convinced I have a paperweight. Someone out there will think of something. Help me!
    kickin_it's Avatar
    62222
    Oct 2012
    18
    Here is my error log from today's attempts on Win 7 using 4.8.
    16:00:25, October 23, 2012
    Line: 518
    ERROR: AP Die ID: 2020030e1a6160010000d8ff0100
    Line: 525
    ERROR: BP Die ID: 0000000000000000b55432890485
    Line: 532
    ERROR: AP Public ID: 730760571fbdde13872f9eb4c958c28284542de3
    Line: 539
    ERROR: BP Public ID: 040000000500000002000000ffff00002d003289
    16:08:01, October 23, 2012
    Line: 960
    ERROR: Interface BP: Error sending RAM download for bootloader. Device API Error: 0xE0030009 Address: 0x19EC00 Command: ADDR
    File: D:\GitProjects\hdt_windows_flash\flash\code\flashd ll\RDLOp.cpp
    Device ID: 0
    Line: 1185
    ERROR: Phone[0000]: Flash failed.
    File: D:\GitProjects\hdt_windows_flash\flash\code\flashd ll\PST_FP_FlashThread.cpp
    Device ID: 0
    Line: 589
    ERROR: Flash failure: Interface BP: Error sending RAM download for bootloader. Device API Error: 0xE0030009 Address: 0x19EC00 Command: ADDR (Error Code: e0030009),
    Detailed Error Details: Direction of the Error=1000, Command Value=200000, Code Group Number=257
    File: D:\GitProjects\hdt_windows_flash\flash\code\flashd ll\FlashHdlr.cpp
    Device ID: 0
    16:10:09, October 23, 2012
    Line: 518
    Line: 525
    Line: 532
    Line: 539
    16:19:35, October 23, 2012
    Line: 1836
    ERROR: Phone[0000]: Error switching phone to BP Pass through mode
    File: D:\GitProjects\hdt_windows_flash\flash\code\flashd ll\FlashOp.cpp
    Device ID: 0
    16:19:46, October 23, 2012
    Line: 713
    ERROR: Phone[0000]: The "Motorola_Flash" Interface could not be found.
    The super-file is not secure and for re-flash;
    the phone needs a super-file that is not secure and for reflash.
    File: D:\GitProjects\hdt_windows_flash\flash\code\flashd ll\MIFlash.cpp
    Device ID: 0
    Line: 589
    ERROR: Flash failure: Phone[0000]: Error switching phone to BP Pass through mode (Error Code: be),
    Detailed Error Details: Direction of the Error=No Direction, Command Value=0, Code Group Number=257
    Device ID: 0
    Rescue Squad
    Points: 27,141, Level: 97
    Level completed: 80%, Points required for next Level: 209
    Overall activity: 6.2%
    Leach19m's Avatar
    31277
    Washington
    7,062
    234 times
    Have you tried to Linux ISO method yet?
    kickin_it's Avatar
    62222
    Oct 2012
    18
    I went with the Linux ISO method. Unfortunately my laptop screen on my Win 7 PC is not working so I have it hooked up with HDMI cable to tv. I tried performing the Linux ISO method and the HDMI cable would not recognize the computer when attempting to boot Ubuntu. I went and purchased a monitor cable and now I can see the screen. Performed the flash, re-booted and once again after wiping cache and factory reset it booted into BootLoader again. I pulled the battery and let it sit for an hour while I made dinner. Come back to the phone and it boots right up. Finally!!!
    Rescue Squad
    Leach19m's Avatar
    31277
    Washington
    7,062
    234 times
    Glad it worked for you!
    kickin_it's Avatar
    62222
    Oct 2012
    18
    Well I spoke to soon. I attempted to activate phone by calling *228, it stated I needed a better signal and to attempt again. I soon as I hit activate button the phone rebooted and were back in BootLoader. Attempting another wipe data wipe cache and battery pull.
    kickin_it's Avatar
    62222
    Oct 2012
    18
    After the wipes the phone is stuck back in bootloader. Well damn, this one may be a paperweight after all.
    Points: 3,108, Level: 34
    Overall activity: 5.0%
    newmanx4's Avatar
    34469
    703
    27 times
    What does the bootloader screen say?
    kickin_it's Avatar
    62222
    Oct 2012
    18
    Bootloader
    30.04
    Battery OK
    Ok to Program
    Connect USB
    Data Cable
    newmanx4's Avatar
    34469
    703
    27 times
    What was your system version before all of this and which SBF did you use?
  1. Anyone Had Success With Smart Actions On The X?
    By music_man185 in forum Droid X General Discussion
    Last Post: 09-12-2012, 03:22 PM
  2. SBF - Detailed Guide for Success - Windows 7
    By macpro88 in forum Droid X SBF
    Last Post: 02-02-2012, 09:19 PM
  3. SBF - Detailed Guide for Success - Windows 7
    By macpro88 in forum Droid X RS Guides
    Last Post: 06-05-2011, 02:34 PM
  4. Replies: 11
    Last Post: 02-24-2011, 04:28 PM
  5. Notice in just shy of two weeks
    By X-Man in forum New Member Introductions & Site Assistance
    Last Post: 08-22-2010, 12:27 PM
atrix sbf fails on error switching phone to bp pass through mode
errorflashear sbf en linux
printable calendar sbf
ubuntu sbf droid x files
