please need HELP .. cant get into stock recovery/factory reset screen!!
This is a discussion on please need HELP .. cant get into stock recovery/factory reset screen!! within the Droid X SBF forums, part of the Droid X Rescue Squad category; ok so heres my situation... i CAN get into bootloader... black screen with white text ,, i CANNOT get into the stock recovery .. black ...
Results 1 to 10 of 11
Thread: please need HELP .. cant get into stock recovery/factory reset screen!!
    Points: 501, Level: 10
    Level completed: 2%, Points required for next Level: 49
    Overall activity: 1.0%
    LiquidFlex81's Avatar
    30382
    6
    i CANNOT get into the stock recovery .. black screen with green text :-(
    i have droid x running froyo 2.3.340 rooted.
    i had to get my phone back to stock one day not too long ago... i went the route of using the team blackhat monster file. it worked, and then i wanted to upgrade to gingerbread. i got the files i needed and thought i was on my way to flashing the upgrade...
    i powered down my phone and tryed to get into the stock recovery by pulling the battery, put it back in, then holding down power button and the home button... saw m logo for a second and screen just goes black... ok.. pulled battery again, tryed to power up normally, saw m logo and just stayed on it forever.. pulled battery again and then try to power up normal again,, this time it worked,, so then i tryed to get into recovery again by using clockworkmod/rom manager... phone powered down, restarted on its own and went to m logo again and just stayed there forever! pulled battery,, put back in,, phone booted up fine..
    so now i realize i have a reboot issuse.. tryed it several more times,, so it always does that now,, normal power down normal power up just hangs at m ogo, pull battery power up and it boots fine. i can get into the bootloader to sbf but i cant complete anything because i cant even do a factory reset... im really upset about this i love my X i cant even complete a factory data reset because when it goes to reboot it goes to a black screen with m logo,, i need to get it into stock recovery somehow or is there another way to factory reset the phone? ju
    st stayed there forever again
    stayed there forever again...
    Points: 26,638, Level: 97
    Level completed: 29%, Points required for next Level: 712
    Overall activity: 62.2%
    Nemo aeternamn's Avatar
    37333
    Mo-ab
    7,738
    165 times
    what are you on now?
    and what recovery are you flashing in rom manager are you flashing?
    Post Script:
    Nemo Aeternamn Wallpapers
    30382
    6
    sorry for the messed up areas of my post moto xoom is acting funny with cursor positions....
    anyways everything i said above and is there another way to factory reset... possibly in android terminal emulator?
    and the other issue im having now since all that is that i cannot install any new apps that need permission of read/modify sd storage.. nor can i update apps that i have already that need that permission.. the only way i got around that issue kind of was by moving any apps i had already installed on the sd was by moving them to the phone, then it let me update them.. but i cant download/install any new apps with that permission... the error message i get is cannot install to usb mass storage or sd card. i also tryed installing backups of apps that i had saved on my sd card already and that didnt work either.. only apps that need that permission... that problem started after i downloaded and installed an app called root system tools... the only function i used in that app was read/write speed testt and then i started getting this new error message. ugh! i really just want my words with friends app back and installed lol but of course it uses that permission... please any and all input is appriciated guys,, i read this board alot and many of yous are sjuper smart,, have great respect fir you ndroid gurus!
    37333
    Mo-ab
    7,738
    165 times
    have ya looked under settings/privacy and do the factory reset there?
    Post Script:
    30382
    6
    Quote Originally Posted by Nemo aeternamn View Post
    i just updated my rom manager recovery to the current version `Current Recovery: Clockworkmod 5.0.2.0`
    what am i on now as in what am i using to reply on this forum? using my moto xoom
    if u mean my droid x its supposed to be froyo 2.3.340 tbh monster file... i used that method because sbf ing seems really confusing with all the info hat is out there now to sbf... i tryed doing the rsd lite way and it failled at the end
    and i tryed flashing before i updated the clockworkmod recovery as well
    30382
    6
    yes and it wont complete that because it will not go to the stock recovery mode to finish.. the screen with the triangle and android guy and exclamation point,, will not go there at all
    37333
    Mo-ab
    7,738
    165 times
    hmm... i've had problems with the aio breaking my stock recovery when i used it to get to 602...and i'd say use this method to sbf... Linux solution to your Windows/RSD lite problems
    it works alot more.... and i feel it works better then the rsd method....and i know it seems complicated... but it's not... just burn disc, reboot computer to disc, run program...
    Post Script:
    30382
    6
    i will try that method of sbfing.. but wont it still need to get into stock recovery to complete the process?
    37333
    Mo-ab
    7,738
    165 times
    most likely... but you can do that after you sbf... after it's cleared out what ever conflict is going on...
    Post Script:
    30382
    6
    i need my stock recovery back is the main issue.. i assume if i get the phone to factory reset somehow,, these problems will be fixed.. so does anyone know of a way to factory reset other than using the stock recovery?
  1. Stock Recovery for Reset After GB 602 SBF
    By reasonthis in forum Gingerbread Development and Hacking
    Last Post: 09-06-2011, 06:12 PM
  2. Black screen after backup assis uninstall/factory reset
    By Midnight Highways in forum Droid X Help
    Last Post: 04-08-2011, 09:08 AM
  3. Get a weird screen/msg when I try to boot into stock recovery
    By spex921 in forum Everything about Gingerbread
    Last Post: 03-29-2011, 07:41 PM
  4. Replies: 3
    Last Post: 03-12-2011, 06:22 PM
  5. Factory Reset: Via Recovery or Interface. Any Diff?
    By UnlikelySalsero in forum Droid X General Discussion
    Last Post: 09-28-2010, 01:31 PM
cannot get droid x2 in stock recovery
cant hard reset droid x
droid 2 stock recovery
droid x blank screen after factory reset
droid x bootloader reset
droid x factory reset from bootloader
how to hard reset droid 2 if screen.doesnt work
how to reset droid x2 if screen is blank
how to reset the droid x2 if the screen is black
how to restore droid 2 when screen is black
