SBF successful, but radio not working and dialer is missing
This is a discussion on SBF successful, but radio not working and dialer is missing within the Droid X SBF forums, part of the Droid X Rescue Squad category; I'll give you the whole backstory. Yesterday morning, I was running stock GB, unrooted, fully official in every way. I decided to put CyanogenMod7 on ...
Thread: SBF successful, but radio not working and dialer is missing
    Points: 919, Level: 16
    Level completed: 19%, Points required for next Level: 81
    3 months registeredTagger Second Class100 Experience Points31 days registered7 days registered
    jazzbassist1's Avatar
    34746
    Ohio
    20
    I'll give you the whole backstory. Yesterday morning, I was running stock GB, unrooted, fully official in every way. I decided to put CyanogenMod7 on my phone. I used the Linux SBF kernel as described in this forum to get back to froyo
    http://www.droidxforums.com/forum/droid-x-sbf/23638-linux-solution-your-windows-rsd-lite-problems.html
    Once I was up and running, I rooted with z4, ran ROM manager and droid 2 bootstrapper (the Cyanogen Wiki told me to use D2 and not DX bootstrapper), flashed Cyanogenmod 7 and the necessary radio fixes, and got it up and running well. Later in the evening, I tried to flash a small update, I cleared user data and the cache, but when I rebooted, I got stuck in bootloop. I tried clearing data/cache again, but it didn't work, so I said screw it, I'll just SBF again and start over.
    This is where the problems come in. I SBF'd, and when I booted up into stock froyo, the cell radio would not connect to Verizon's network, and there are a few apps missing, notably the Dialer and just about anything associated with making phone calls. I managed to sideload the bootstrap and ROM manager, but ROM manager would not work properly even though I was connected to wifi. I've tried the SBF again and the same thing happened
    So my issue is that I don't have any cell signal and or any way to install a ROM that would allow me to control the cell radio. Does anyone have any idea how to fix this? Any help would be greatly appreciated, I really hope I didn't brick this sucker.
    Points: 15,172, Level: 79
    Overall activity: 14.0%
    cory46's Avatar
    8051
    4,768
    125 times
    After the sbf did you enter stock recovery above wipe data/ factory reset?
    34746
    Ohio
    20
    Yes I went in to stock recovery and cleared the data/factory reset, and I also wiped the cache, and reformatted my SD card just for good measure (I have a backup of the SD card on my computer)
    34746
    Ohio
    20
    Ok, so most of this work I did last night, and I woke up this morning and everything was still wrong, so I decided to give it one more go. With a nearly empty SD card, and data/cache wipe, I SBF'd, and it worked. Strange. Maybe I missed a step without realizing it.
    I wanted to post my fix just for future reference in case someone else screws up their phone as much as I did That's what this forum is all about!
  1. Missing FM Radio apk?
    By radioz in forum ApeX
    Last Post: 10-19-2011, 10:48 PM
  2. Dialer not working
    By dpwicz in forum Droid X Help
    Last Post: 08-03-2011, 08:01 AM
  3. DX Gingerbread Browser Dialer Shortcut not working
    By Jrod301 in forum Droid X Help
    Last Post: 06-27-2011, 11:09 AM
  4. Dialer stopped working all of a sudden.
    By droidernoob in forum Droid X Help
    Last Post: 04-13-2011, 08:39 PM
  5. Dialer not working since lcd density change
    By dropd1us in forum Droid X Apps
    Last Post: 03-23-2011, 04:16 PM
Droid x dialer not working
cyanogenmod dialer missing
cyanogenmod missing dialer
data radio not working on droid x
droid 3 radio not working
droid 3 sbf no radio
droid x radio not working
droid. x radio fix
milestone x sbf
milestone x sbf fix
