Bootloader help - RSD/Linux methods not working - Bricked
This is a discussion on Bootloader help - RSD/Linux methods not working - Bricked within the Droid X SBF forums, part of the Droid X Rescue Squad category; So... I'm back again with more problems than I had before. ^^; After getting such helpful advice last time, I feel it's time to come ...
Results 1 to 9 of 9
Thread: Bootloader help - RSD/Linux methods not working - Bricked
    Achiga's Avatar
    35560
    California
    7
    So...
    After getting such helpful advice last time, I feel it's time to come back again since my phone isn't really responding to anything I do.
    My phone is bricked. I tried (stupidly and highly ineffectively) to flash my phone from Liberty GB v0.9 to 2.3.15... Now my phone simply won't start. I try t turn it on and I get the liberty symbol, but I get no boot animation, nor can I get into clockworkmod recovery.
    I manage to get into bootloader, and I have tried (and failed) many times so far to sbf my phone.
    When I ran into a problem before, I simply used this method to get me out of it: Linux solution to your Windows/RSD lite problems
    It worked the first time, but since I'm using another computer and don't have access to the older one, I had to re-install all the files again to use it. This is where I come into an issue.
    I grab the iso, and I "burn" it to my USB thumb drive, but when I go to load it up, it takes me to a UNetbootin menu with several options:
    "Default
    Slitaz
    web
    zeb
    us"
    If I choose anything but "Slitaz", it gives me the error of: "Could not find ramdisk image: /ubninit". If I choose "Slitaz", then it takes me a through a string of code and makes my screen look like it's been run over by a car.
    After failing in this, I moved to the simpler RSD method. I grabbed the latest sbf from: https://sites.google.com/site/1kdsdroidx/home and attempted to work through my problem. RSD failed me. I uninstalled it, re-installed the new Motorola drivers, re-installed it, still nothing, messed around with some settings, nothing. I click the start button, and it seems as if it attempts nothing and just gives me a "FAIL" error message.
    That's all I really have to say about that... I have nothing else to try, so if there's anything out there that can help, please let me know!
    Thanks in advance,
    ~Achiga
    Points: 19,500, Level: 88
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,140
    200 times
    For the USB drive, you don't need to select a distribution...select diskimage at the bottom and then the ...'s to find 1KDS' .iso file. Here are instructions on how to burn with Unetbootin
    Achiga's Avatar
    35560
    California
    7
    I did that method and I still got that error, even after formatting the USB a few times and retrying the method with UNetbootin.
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,140
    200 times
    If you have a disc you can burn, it sometimes has more success...but for RSD lite, try rebooting your PC and move the sbf file to your desktop and give it a try again. Also, make sure you are running RSD as an administrator if on Vista or Win 7.
    And keep your phone powered down in between attempts so that you don't drain the battery. It likely won't charge in that state, so if it dies, you'll have to get a charged battery some other way.
    Points: 67,578, Level: 100
    Overall activity: 16.2%
    HarleyDude's Avatar
    19213
    Philly area
    8,191
    460 times
    I get the same option when I boot off flash, just pick slitaz, that's the distro the 1KDStaz.iso is built on. It just sounds like your on a computer that won't support the video resolution of the 1KDS utility, so you'll need to use another PC
    Achiga's Avatar
    35560
    California
    7
    @C Dippa: My RSD is constantly in Admin mode. Moving the files to the desktop didn't help, but moving them to a folder got it to start executing the process. It's a bit weird that it did that, but I'll take what I can get at this point. Thanks for the help. I hope this works.
    @HarleyDude What's the video resolution of it? x: My laptop can play 1080 and 720 videos just fine, or is that too high for it?
    HarleyDude's Avatar
    19213
    Philly area
    8,191
    460 times
    Its set much higher in the iso, 1600x1200 I believe
    Achiga's Avatar
    35560
    California
    7
    my overall resolution is 1920x1200 x:
    HarleyDude's Avatar
    19213
    Philly area
    8,191
    460 times
    Well then, the laptop should handle it just fine, so I'm not sure
    If you can get an older version of the iso, either .7 ot .8, you get the option to set the video resolution.
  1. Trying to SBF in Linux, may have bricked
    By jazzbassist1 in forum Droid X Help
    Last Post: 05-26-2011, 11:09 AM
  2. Alternative Methods to Rooting
    By hannja in forum Droid X Hacks
    Last Post: 12-27-2010, 03:23 AM
  3. Bricked/ 30.04 bootloader
    By debdado in forum Droid X Rescue Squad
    Last Post: 12-22-2010, 09:47 AM
  4. Bricked my x RSD not working help!!
    By mkcm97 in forum Droid X Help
    Last Post: 11-14-2010, 10:00 AM
  5. Best Battery Life Methods
    By wagman67 in forum Droid X Hacks
    Last Post: 11-05-2010, 10:21 AM
bricked droid x bootloader
could not find ramdisk image ubninit
could not find ramdisk image: /ubninit
force droid x into bootloader
rsd linux
rsd not working
unetbootin could not find ramdisk image
unetbootin could not find ramdisk image ubninit
unetbootin could not find ramdisk image: /ubninit
www.droidxforums.com 32167-bootloader-help-rsd-linux-methods-not-working-bricked
