Red alert!
This is a discussion on Red alert! within the Droid X SBF forums, part of the Droid X Rescue Squad category; I sbf'd to stock the other day, and I took the update to offical GB. I just tried to SBF using the normal sbf file ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Red alert!
    Points: 2,946, Level: 33
    Level completed: 31%, Points required for next Level: 104
    TheJustPull's Avatar
    28826
    580
    Red alert!
    I sbf'd to stock the other day, and I took the update to offical GB. I just tried to SBF using the normal sbf file I had but it failed, and now its stuck on SW update in progess. Did I use a wrong file, or how/ is there a fix for this? I also need to figure out how to get my battery out as the tab popped out, my fat one I could get out no problems but this one is tight.. Ugh, I just want to be able to use my phone in landscape and portrait again :<
    Update: I got the battery out and it is now saying code corrupt, so I'm thinking getting the wrong file? Is there a new sbf we're supposed to use for the new build?
    Formerly known as Haywire
    Points: 7,762, Level: 59
    Overall activity: 1.2%
    mopar-x's Avatar
    22071
    Buffalo N.Y.
    1,132
    56 times
    should be the same SBF if your using rsd light try this .
    Sent from Mopar-x
    Points: 38,766, Level: 100
    Overall activity: 64.5%
    1KDS's Avatar
    3981
    6,904
    573 times
    You should be using the full 2.3.340 file, you can get it here. If that is the file you have used then I would reboot the PC and give it another shot.
    28826
    580
    I re-downloaded the file, I am attempting it again, I wasnt sure if I was supposed to use a new file or not, I've never had it go bad on me like that. I was scared its cause I dont have bootstrap or anything on it right now.
    28826
    580
    Okay, It just loaded up on .340. To take it back to Liberty what are the files I need to install on it? Same from the TBH Page?
    mopar-x's Avatar
    22071
    Buffalo N.Y.
    1,132
    56 times
    Are you going to rooted GB?
    Sent from Mopar-x
    28826
    580
    eventually but not sure what i neee tobdownload
    mopar-x's Avatar
    22071
    Buffalo N.Y.
    1,132
    56 times
    Well if your on rooted froyo and want to go to rooted GB you can get it here in this link.
    Official DX Gingerbread 2.3.3 (4.5.596) Release Thread - Something for everyone
    Sent from Mopar-x
    28826
    580
    I guess I should probably start with rsd lite eh?
    mopar-x's Avatar
    22071
    Buffalo N.Y.
    1,132
    56 times
    Or you can use the ezSBF link in 1KDS sig.
    Sent from Mopar-x
  1. No text alert
    By fball9709 in forum Droid X Rescue Squad
    Last Post: 04-18-2011, 08:26 AM
  2. Phantom Alert app
    By gwilde in forum Droid X Apps
    Last Post: 03-20-2011, 10:58 PM
  3. Message Alert
    By 2quik in forum Droid X Help
    Last Post: 03-06-2011, 08:49 AM
  4. Alert light
    By Anthony 23 in forum Droid X Help
    Last Post: 02-26-2011, 07:43 AM
  5. Connection available alert.
    By PorcPuffer in forum Droid X Help
    Last Post: 07-21-2010, 07:16 AM
droid 3 alert light not working text
droid 3 message alert
phantom alert app threads
red alert for droid
red alert light on droid
red alert on droid
red x alert on droid
