[VIDEO GUIDE] How to SBF Your Droid X WITHOUT USING RSDLITE
This is a discussion on [VIDEO GUIDE] How to SBF Your Droid X WITHOUT USING RSDLITE within the Droid X RS Video Guides forums, part of the Droid X RS Guides category; Originally Posted by GoCliffGo05 Just before it says loading windows did you see something on screen that says "boot from cd" real quick? Press a ...
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 22 of 22
Like Tree20Likes
Thread: [VIDEO GUIDE] How to SBF Your Droid X WITHOUT USING RSDLITE
  1. #21
    Just before it says loading windows did you see something on screen that says "boot from cd" real quick? Press a key when you see that. Also did you save your changes before you exited BIOS? Another simple question is are you sure your cd drive works? Can you run a cd normally when the operating system is on?By the way sarcasm isn't tolerated around here. We will do our best to get you up and running.
    I did get to the manual boot screen on the PC and tried 3 or 4 times by selecting boot from cd. It kicks the cd drive on and after about 5 seconds it just goes into loading XP. I then went into BIOS and set it to boot from cd first and restarted. It kicks on the cd drive and shortly after it loads XP. The CD drive works great and I checked the disc and it has the iso on it. The only thing I can think to do is find another pc to try the disc on. Cheers,1/2 man 1/2 bear 1/2 pigManbearpig
  3. #22
    Points: 3,098, Level: 34
    Level completed: 32%, Points required for next Level: 102
    Overall activity: 7.9%
    newmanx4's Avatar
    34469
    703
    27 times
    Could be that the ISO is not burned properly, therefore the PC can't boot from it. How did you burn it?
    Sent from my Black Iced X
  1. Replies: 2
    Last Post: 10-09-2011, 07:13 PM
  2. [HD VIDEO GUIDE]How to Install Sensei Mod GB 602 Rom
    By RageXmods in forum Gingerbread Roms
    Last Post: 10-09-2011, 07:12 PM
  3. Replies: 0
    Last Post: 10-09-2011, 10:44 AM
4.5.629 sbf
4.5.629 sbf#gsc.tab
droid 2 3.4.5 621 root
droid x sbf guide
how-to unbrick your droid x using sbf
manually downgrade droid x without rsd lite
sbf 4.5.629
sbf without rsd lite
video guide how to sbf your droid x
video guide how to sbf your droid x without using rsdlite
