[HOW TO] Install and Remove Bootstrap Recovery
This is a discussion on [HOW TO] Install and Remove Bootstrap Recovery within the Droid X RS Guides forums, part of the Droid X Discussion category; Before installing I HIGHLY recommend that you have rsdlite and you have it ready to go if needed: Ready to go means that you have ...
Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 53
Like Tree5Likes
Thread: [HOW TO] Install and Remove Bootstrap Recovery
    Points: 25,696, Level: 96
    Level completed: 35%, Points required for next Level: 654
    Abe21599's Avatar
    Ohio
    4,864
    458 times
    Before installing I HIGHLY recommend that you have rsdlite and you have it ready to go if needed: Ready to go means that you have used it before and tested it to make sure it will work. If you wait until you have problems to run rsdlite then you are more likely to panic. I would make sure that everything is set up and ready to go just in case.
    Installing Bootstrap Recovery (thanks to Wimervision for the video):
    Removing Bootstrap Recovery:
    Removal from an Androidforums post:
    UNINSTALL the Recovery APK (Droid X Bootstrapper) in Settings, Applications
    Reboot
    Run "adb shell"
    Run "su"
    Run "mount -o remount,rw /dev/block/mmcblk1p21 /system"
    Run "cp /system/bin/logwrapper.bin /system/bin/logwrapper"
    Reboot
    or
    1. Reroot
    2. Get root explorer in the market
    3. Uninstall the bootstrap app
    4. Go into root explorer to system/bin
    5. In top right corner tap r/w
    6. Delete the file called hijack
    7. Delete logwrapper
    8. Rename logwrapper.bin to just logwrapper
    9. Reboot and it should be gone.
    (thanks to Droidforums member Hostility6)
    The commands can be used with terminal emulator do all the commands except for the first command. (Run adb shell)
    Heres some info on how to actually use the bootstrap.
    http://www.droidxforums.com/forum/ha...bootstrap.html
    Thanks to PC747 over on DF for originally putting this together
    Abe21599's Avatar
    Ohio
    4,864
    458 times
    reservedd
    I deleted hijack and logwrapper and renamed logwrapper.bin and it worked. But now I want to use clockwork again. how do i undo what i did. reinstalled bootstrapper but it dosent work and I noticed that even after reinstalling it, the hijack is missing, and there is only the one logwrapper file. Can i download those single files alone?
    Abe21599's Avatar
    Ohio
    4,864
    458 times
    Quote Originally Posted by t.noroeste View Post
    reflashing bootstrap using koushs app doesnt work?
    Points: 1,220, Level: 19
    Level completed: 20%, Points required for next Level: 80
    bullysonx's Avatar
    27847
    San Diego, CA
    82
    Stupid question but when you mentioned sys/bin is this the same thing as folder?
    Nope, says bootstrap is success, but goes in to android recovery instead.
    Also I should note, im still getting a liberty bootup icon every time I boot up right in the becoming even before the system recovery comes up. I had liberty loaded and has been doing this since.
    bullysonx's Avatar
    27847
    San Diego, CA
    82
    Quote Originally Posted by bullysonx View Post
    Forget my post I found it..duh dumb azz..lol
    Points: 7,455, Level: 57
    Level completed: 53%, Points required for next Level: 95
    1000 Experience Points7 days registered500 Experience Points250 Experience Points100 Experience Points
    bignasty407's Avatar
    34145
    TENN A KEY
    498
    26 times
    how do i run adb shell? im confused on how exactly to do this :/
    Points: 42,982, Level: 100
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,335
    786 times
    in terminal emulator or if you have adb setup on your pc
    34145
    TENN A KEY
    498
    26 times
    Quote Originally Posted by Droid-Xer View Post
    i have adb in my c:\ drive. in an sdk fold. sorry im just confused i put in all the other code that it calls for in the intsructions. and rooboted will it even work if i dont run adb shell, i tried in TE and it said denied.
  1. DX Bootstrap Recovery documentation??
    By bobthebob in forum Droid X Help
    Last Post: 11-03-2010, 02:03 PM
  2. Remove Clockwork Recovery?
    By mreyeball in forum Hacking Help
    Last Post: 11-01-2010, 06:02 PM
  3. Replies: 1
    Last Post: 10-06-2010, 12:23 PM
  4. Droid X Bootstrap Recovery by Koush
    By JMuldrow in forum Droid X General Discussion
    Last Post: 08-21-2010, 03:17 PM
  5. Replies: 7
    Last Post: 07-16-2010, 06:55 PM
Droid X Recovery Bootstrap apk
como desinstalar o bootstrapper
como remover bootstrapper
desinstalar bootstrap
how to remove bootstrap
how to remove bootstrap recovery
how to uninstall bootstrap
remove bootstrap
uninstall bootstrap
