[GUIDE] How to root your phone with zergRUSH
This is a discussion on [GUIDE] How to root your phone with zergRUSH within the Droid X RS Approved Guides forums, part of the Droid X RS Guides category; Original post by DooMLoRD at xda: http://forum.xda-developers.com/show....php?t=1321582 This method is known to work on all versions of the Droid X and X2 software updates. It ...
Page 1 of 8 1 2 3 ... LastLast
Results 1 to 10 of 76
Like Tree5Likes
Thread: [GUIDE] How to root your phone with zergRUSH
    Points: 10,859, Level: 69
    Level completed: 3%, Points required for next Level: 391
    Overall activity: 65.3%
    juhde's Avatar
    38196
    New Mexico
    1,716
    52 times
    This method is known to work on all versions of the Droid X and X2 software updates. It does require that you use a PC to obtain root but the method VERY fast!
    Just download the attached file, extract it using winzip/winrar
    Go to the folder where its extracted and execute "RUNME.bat"
    Read and follow the instructions on the screen!
    Easy rooting toolkit (v3.0)
    created by DooMLoRD
    using exploit zergRush
    (Revolutionary Team)
    Credits go to all those involved in making this possible!
    ---------------------------------------------------------------[*] This script will:
    (1) root your device using latest zergRush exploit (16 Nov)
    (2) install Busybox (1.18.4)
    (3) install SU files (binary: 3.0.3 and apk: 3.0.6)
    [*] Before you begin:
    (1) make sure you have installed adb drivers for your device
    (2) enable "USB DEBUGGING"
    from (Menu\Settings\Applications\Development)
    (3) enable "UNKNOWN SOURCES"
    from (Menu\Settings\Applications)
    (4) [OPTIONAL] increase screen timeout to 10 minutes
    (5) connect USB cable to PHONE and then connect to PC
    I have found that once you connect your phone to the PC the Motorola ADB drivers will be automatically installed so this method is really straight forward. Pretty much all you need to do is download it, run it, follow the instructions, connect your phone, set the USB mode to "charge only" and start the rooting process!
    Download version 3
    Points: 161, Level: 3
    Level completed: 22%, Points required for next Level: 39
    Overall activity: 2.3%
    31 days registered100 Experience Points7 days registered
    matthewc777's Avatar
    53356
    Dec 2011
    24
    is it supposed to sit at the "daemon started successfully" screen for a bit?
    juhde's Avatar
    38196
    New Mexico
    1,716
    52 times
    A few seconds maybe, not too long. The whole process should only take about 2 minutes once you press any key to start it.
    Sent from my Android device.
    53356
    Dec 2011
    24
    hm. thanks for the quick response. new to this rooting thing. trying to understand it. it sat at that status for a few minutes so i closed her.
    53356
    Dec 2011
    24
    also is the 2.3.5 update for the latest version of blur?
    53356
    Dec 2011
    24
    still not workin for me for some reason. does it need to be in mass storage mode?
    juhde's Avatar
    38196
    New Mexico
    1,716
    52 times
    Charge only mode.
    Did you enable usb debugging and unknown sources?
    It's the same blur as 2.3.4.
    53356
    Dec 2011
    24
    Hey thanks again. Yes I enabled both. I also got started ln this whole thing trying To run eclipse which I believe was a post of yours on how to. So I read quite a bit about it first. My phone did an update just a few days ago. So I don't need to worry about that do I ?
    juhde's Avatar
    38196
    New Mexico
    1,716
    52 times
    Quote Originally Posted by matthewc777 View Post
    A long as the 2.3.5 update installs for you you're fine.
    Did you get it rooted?
    53356
    Dec 2011
    24
    When I tried to grab the 2.3.5 it takes me to a file for the same version my phone is already on. So if I am still stock then I need to do the flash step to get it to 2.3.5 . Not rooted yet. 1.3.380. Is what I'm on and its 2.3.4 ginger.
download zergrush
download zergrush root
droid x2 zerg rush
how to root droid x 2.3.4
root zergrush
zerg root
zerg root one click
zerg rush android
zerg rush root
zerg rush root download
zergroot
zergrush apk
zergrush download
zergrush root
zergrush root download
