[GUIDE] How to root your phone with zergRUSH
This is a discussion on [GUIDE] How to root your phone with zergRUSH within the Droid X RS Approved Guides forums, part of the Droid X RS Guides category; Can I root Droid X with System Version 4.5.621.MB810? I just got done rooting a Droid X with 4.5.605 but I didn't get SuperUser on ...
Page 8 of 10 FirstFirst ... 6 7 8 9 10 LastLast
Results 71 to 80 of 94
Like Tree6Likes
Thread: [GUIDE] How to root your phone with zergRUSH
  1. #71
    Points: 355, Level: 7
    Level completed: 10%, Points required for next Level: 45
    mrbuilder's Avatar
    57284
    Can I root Droid X with System Version 4.5.621.MB810? I just got done rooting a Droid X with 4.5.605 but I didn't get SuperUser on 4.5.621.
    Thanks in advance!
  3. #72
    Points: 22,573, Level: 93
    Level completed: 23%, Points required for next Level: 777
    Overall activity: 38.8%
    Nemo aeternamn's Avatar
    37333
    Mo-ab
    7,634
    134 times
    Quote Originally Posted by mrbuilder View Post
    Thanks in advance!
    No... That version is unrootable so far...
    But you can use the milestone sbf to 604 using the Linux method.. Then you can use this method to root it
    "I'll get you my little pretty... and your little dog todo too"
    "I don't even have a little dog todo"
    Post Script:
    Nemo Aeternamn Wallpapers
  4. #73
    I am trying to do this but it keeps saying that the adb driver can not be installed and that I need to install the disc.
    I am lost.
    I would appreciate any help. Thanks
  5. #74
    Help. Tried running this, getting "no space left on device" I have about 5 gig left on the phone, and 10 gig or so on the SD card.
    When I hook the phone up and start to run the program (I've done the usb stuff), I get a note on the phone saying "SD storage device safe to remove" - like it's disconnecting the SD.
    One thing I'm not 100% sure about is if I have the correct drivers loaded. I ran ChevyNo1 packet, and when I check for the device, see this.
    015A7A371902B018 device
    What am I missing?
  6. #75
    Points: 278, Level: 5
    Level completed: 56%, Points required for next Level: 22
    antigovx's Avatar
    55283
    7
    Currently rooted on version 4.5.605.MB810.Verizon, but keep receiving a message: Download for version 4.5.621 will start in 28 sec. Oviously i decline, but is there a way to avoid this update so no changes are made to my currently rooted phone?
  7. #76
    Points: 599, Level: 11
    Level completed: 98%, Points required for next Level: 1
    metropcsflash's Avatar
    43984
    Jul 2011
    Ok I have USB debug on Unknown sources on and charge only with the latest Mot drivers and I can not get this to work. I keep getting the same error for every command the system can not find the path specified. What am I doing wrong?? I have a DX2 running 2.3.5 version 1.3.412.MB810.Verizon.en.US. Thanks
  8. #77
    Rooting Sony Ericsson Xperia Play Build 4.0.2.E.0.57
    OK first the details;
    Windows 7
    USB connected to phone
    USB Debuging enabled
    ......could not find "adb drivers" for this phone...........
    Android version 2.3.4
    Verizon
    Model R800x
    Tried ZergRUSH
    Got this as screen shot.....
    Easy rooting toolkit (v3.0)
    created by DooMLoRD
    using exploit zergRush (Revolutionary Team)
    Credits go to all those involved in making this possible!
    [*] This script will:
    (1) root ur device using latest zergRush exploit (16 Nov)
    (2) install Busybox (1.18.4)
    (3) install SU files (binary: 3.0.3 and apk: 3.0.6)
    [*] Before u begin:
    (1) make sure u have installed adb drivers for ur device
    (2) enable "USB DEBUGGING"
    from (Menu\Settings\Applications\Development)
    (3) enable "UNKNOWN SOURCES"
    from (Menu\Settings\Applications)
    (4) [OPTIONAL] increase screen timeout to 10 minutes
    (5) connect USB cable to PHONE and then connect to PC
    (6) skip "PC Companion Software" prompt on device
    CONFIRM ALL THE ABOVE THEN
    Press any key to continue . . .
    --- STARTING ----
    --- WAITING FOR DEVICE
    --- cleaning
    rm failed for *, No such file or directory
    --- pushing zergRush"
    682 KB/s (23056 bytes in 0.033s)
    --- correcting permissions
    --- executing zergRush
    [**] Zerg rush - Android 2.2/2.3 local root
    [**] (C) 2011 Revolutionary. All rights reserved.
    [**] Parts of code from Gingerbreak, (C) 2010-2011 The Android Exploid Crew.
    [+] Found a GingerBread ! 0x00015118[*] Scooting ...[*] Sending 149 zerglings ...[*] Sending 189 zerglings ...
    [-] Hellions with BLUE flames !
    --- WAITING FOR DEVICE TO RECONNECT
    if it gets stuck over here for a long time then try:
    disconnect usb cable and reconnect it
    toggle "USB DEBUGGING" (first disable it then enable it)
    --- DEVICE FOUND
    --- pushing busybox
    1510 KB/s (1075144 bytes in 0.695s)
    --- remounting /system
    mount: permission denied (are you root?)
    --- copying busybox to /system/xbin/
    /system/xbin/busybox: cannot open for write: Read-only file system
    --- correcting ownership
    Unable to chmod /system/xbin/busybox: No such file or directory
    --- installing busybox
    /system/xbin/busybox: not found
    --- pushing SU binary
    failed to copy 'files\su' to '/system/bin/su': Read-only file system
    Unable to chmod /system/bin/su: No such file or directory
    --- correcting symlinks
    rm failed for /system/xbin/su, Read-only file system
    link failed Read-only file system
    --- pushing Superuser app
    failed to copy 'files\Superuser.apk' to '/system/app/./Superuser.apk': Read-only
    file system
    --- cleaning
    --- rebooting
    ALL DONE!!!
    Any Help would be GREATLY appreciated.
    Thanks!!!!!!
    maldita likes this.
  9. #78
    Quote Originally Posted by SSGRichDAV View Post
    OK first the details;<br>
    Windows 7<br>
    USB connected to phone<br>
    USB Debuging enabled<br>
    ......could not find "adb drivers" for this phone...........<br>
    Android version 2.3.4<br>
    Verizon<br>
    Model R800x<br>
    <br>
    Tried ZergRUSH<br>
    Got this as screen shot.....<br>
    <br>
    ---------------------------------------------------------------<br>
    Easy rooting toolkit (v3.0)<br>
    created by DooMLoRD<br>
    using exploit zergRush (Revolutionary Team)<br>
    Credits go to all those involved in making this possible!<br>
    ---------------------------------------------------------------<br>[*] This script will:<br>
    (1) root ur device using latest zergRush exploit (16 Nov)<br>
    (2) install Busybox (1.18.4)<br>
    (3) install SU files (binary: 3.0.3 and apk: 3.0.6)<br>[*] Before u begin:<br>
    (1) make sure u have installed adb drivers for ur device<br>
    (2) enable "USB DEBUGGING"<br>
    from (Menu\Settings\Applications\Development)<br>
    (3) enable "UNKNOWN SOURCES"<br>
    from (Menu\Settings\Applications)<br>
    (4) [OPTIONAL] increase screen timeout to 10 minutes<br>
    (5) connect USB cable to PHONE and then connect to PC<br>
    (6) skip "PC Companion Software" prompt on device<br>
    CONFIRM ALL THE ABOVE THEN<br>
    Press any key to continue . . .<br>
    --- STARTING ----<br>
    --- WAITING FOR DEVICE<br>
    --- cleaning<br>
    rm failed for *, No such file or directory<br>
    --- pushing zergRush"<br>
    682 KB/s (23056 bytes in 0.033s)<br>
    --- correcting permissions<br>
    --- executing zergRush<br>
    <br>
    [**] Zerg rush - Android 2.2/2.3 local root<br>
    [**] (C) 2011 Revolutionary. All rights reserved.<br>
    <br>
    [**] Parts of code from Gingerbreak, (C) 2010-2011 The Android Exploid Crew.<br>
    <br>
    [+] Found a GingerBread ! 0x00015118[*] Scooting ...[*] Sending 149 zerglings ...[*] Sending 189 zerglings ...<br>
    [-] Hellions with BLUE flames !<br>
    --- WAITING FOR DEVICE TO RECONNECT<br>
    if it gets stuck over here for a long time then try:<br>
    disconnect usb cable and reconnect it<br>
    toggle "USB DEBUGGING" (first disable it then enable it)<br>
    --- DEVICE FOUND<br>
    --- pushing busybox<br>
    1510 KB/s (1075144 bytes in 0.695s)<br>
    --- remounting /system<br>
    mount: permission denied (are you root?)<br>
    --- copying busybox to /system/xbin/<br>
    /system/xbin/busybox: cannot open for write: Read-only file system<br>
    --- correcting ownership<br>
    Unable to chmod /system/xbin/busybox: No such file or directory<br>
    --- installing busybox<br>
    /system/xbin/busybox: not found<br>
    --- pushing SU binary<br>
    failed to copy 'files\su' to '/system/bin/su': Read-only file system<br>
    Unable to chmod /system/bin/su: No such file or directory<br>
    --- correcting symlinks<br>
    rm failed for /system/xbin/su, Read-only file system<br>
    link failed Read-only file system<br>
    --- pushing Superuser app<br>
    failed to copy 'files\Superuser.apk' to '/system/app/./Superuser.apk': Read-only<br>
    file system<br>
    --- cleaning<br>
    --- rebooting<br>
    ALL DONE!!!<br>
    <br>
    I am getting the same error. Trying to root HTC ChaCha S-On&nbsp;<br>
    Any Help would be GREATLY appreciated.<br>
    <br>
    Thanks!!!!!!
    I am getting the same error when attempting to root HTC ChaCha S-On
  10. #79
    Points: 15,911, Level: 81
    Level completed: 13%, Points required for next Level: 439
    Overall activity: 79.3%
    BHuber09's Avatar
    34670
    Atlantis
    5,522
    136 times
    You're having the error whenever it changes permission and or remounting it appears. Honestly I'm not sure how that can be fixed either.
    So my generic solution is redownload zergrush and try again.
    Also go http://www.htcforums.com/chacha/ and ask, someone is more likely to know how to help you with you're phone.
    Tapp'd from one of my Nexus Devices
    FreeMyMoto!!!
    If you need help PM me!!!
  11. #80
    --------------------------------------------------------------- Easy rooting toolkit (v3.0)
    created by DooMLoRD
    [*] Before u begin:
    Πιέστε ένα πλήκτρο για συνέχεια. . .
    --- STARTING ----
    --- cleaning
    351 KB/s (23056 bytes in 0.064s)
    [+] Found a GingerBread ! 0x00016118[*] Scooting ...[*] Sending 149 zerglings ...[*] Sending 189 zerglings ...
    --- DEVICE FOUND
    --- pushing busybox
    2091 KB/s (1075144 bytes in 0.502s)
    file system
    --- cleaning
    --- rebooting
    ALL DONE!!!
    Quote Originally Posted by maldita View Post
    I'm also getting the same messages and rooting fails.
    I have an HTC clone.
    Every program I tried finds the same obstacle.
    The phone is set corectly, recognized, all drivers set but still no success.
    PLEASE HELP!
zerg root
zerg root one click
zerg rush android
zerg rush download
zerg rush root
zerg rush root download
zergrush apk
zergrush download
zergrush root
zergrush root download
