stuck at bootloader
This is a discussion on stuck at bootloader within the Droid X Rooted Issues forums, part of the Droid X Rescue Squad category; sorry for starting another thread, but i attempted to debrick my phone using this guide and am now having different issues. Unbricking Your Droid X ...
Results 1 to 10 of 10
  • 1 Post By e3zkiel
Thread: stuck at bootloader
    Points: 865, Level: 15
    Level completed: 65%, Points required for next Level: 35
    paterpan's Avatar
    14133
    5
    stuck at bootloader
    Unbricking Your Droid X - Droid Forum - Verizon Droid & the Motorola Droid Forum
    unfortunately now my phone is stuck at bootloader with this message
    Bootloader
    30.03
    Err:A5,70,70,00,1F
    MEW_Map Blank
    Service Req'd
    Battery K
    OK to Program
    Transfer mode:
    USB
    earlier my issue was
    "phone stuck at motorola logo
    Phone is rooted. I was attempting to deodex my droidx and after the cmd prompt portion i got an error(forgot what it was) then phone rebooted and has been stuck on the motorola load screen. Ive tried leaving out the battery and sd card for a while. ive tried turning it on with and without the sd card all with no luck.
    this is the thread i was using to deodex
    [HOW-TO] Manually deodex your phone."
    dunno what to do.. any advice would be GREAT!
    thanks in advance
    spiffyfitz's Avatar
    14141
    5
    My issue is similar... Originally I was just trying to get rid of the blur crap that came with the phone.. Tried installing Rubix, stuck at M logo without any CM Recovery so I went straight to RSD Lite with an SBF file named VRZ_MB810_1.13.6.2_1FF_01.sbf
    Same issues as before, so I tried a newer SBF named SHADO_X6_2.3.13_SYSTEM-ONLY..
    Now when I boot, it takes me straight into the bootloader...
    So I tried VRZ_MB810_1.13.6.2_1FF_01.sbf one more time and it took me straight into the OS... looks like a 2.1, hopefully I will be offered the 2.2 OTA upgrade and I can upgrade back to Froyo legitimately... but then I'll be back to square 1... with crappy blur software...
    mau's Avatar
    12822
    33
    I hope you get this fixed. I'm glad I saw this post as I was just about to do the Manual Deodex process.
    Amamendola's Avatar
    8567
    Quote Originally Posted by paterpan View Post
    Bootloader
    30.03
    Err:A5,70,70,00,1F
    MEW_Map Blank
    Service Req'd
    Battery K
    OK to Program
    Transfer mode:
    USB
    thanks in advance
    Well ur pretty much screwed. Until the full sbf file leaks your only option is to tell verizon that the 2.2 update did that to your phone. I sbf'ed the 2.1 file trying to downgrade from 2.2 and bricked. Same error code. Your battery also will not charge so dont keep trying to flash ur phone. If your phone does die or it says battery low unable to program. You can take a old usb cord and cut the tip that you plug into your phone off. Splice the red (positive) and black (negitive) wires and rest them on the corresponding connectors on your battety while plugged into your computer. Battery is out of the phone while you do that by the way
    Its def a lot easier to get a replacement from verizon.
    paterpan's Avatar
    14133
    5
    so when the full sbf comes out itll fix it? i got a replacement.. but they didnt take the broken one so now i have a brick and a working one.. hoping i can fix the brick and sell it or something..
    Gunkle's Avatar
    868
    52
    It now has a bad esn with verizon so it can't be activated again. They keep track of what phones they replace
    Points: 10,255, Level: 67
    Backnblack's Avatar
    26
    2,816
    139 times
    Parts is all it's good for......It'll never work on VZW again...
    Only the Skilled Survive
    1. Never be unarmed.
    2. See Rule #1
    Points: 1,052, Level: 17
    kk4df's Avatar
    8028
    47
    P3droid was looking for a bricked phone yesterday to do some testing with. If you were lucky, it might come back unbricked. He's with TBH working on cracking the bootloader and maybe a 2.2 SBF. You might contact him.
    I got this so i am brick also the only thing i did was try to downgrade any help' can i use a different sbf to fix this problem i was using the VRZ_mb810 2.1 to downgrade. the phone was on verizon 2.2
    Bootloader
    30.03
    Err:A5,70,70,00,1F
    MEW_Map Blank
    Service Req'd
    Battery K
    OK to Program
    Transfer mode:
    USB
    Points: 2,861, Level: 32
    e3zkiel's Avatar
    6303
    California
    193
    11 times
    You cannot downgrade using the 2.1 sbf when your bootloader has been updated with new keys. If it says 30.01 you can use the old 2.1 sbf. If it's 30.03 you only can use the new 2.2 sbf that has been leaked.
    quentin likes this.
    Nokia handheld -> LG flip phone -> Storm -> Droid X
    ROOTED and lovin' it
    running Android
    4.0.4 - currently using Gummy 1.2.0 - 5/9/12 [BETA]
  1. Bootloader Issues
    By phlebotomist in forum Droid X Rooted Issues
    Last Post: 11-15-2010, 12:26 AM
  2. DroidX Bootloader
    By tx3 in forum Droid X Hacks
    Last Post: 09-28-2010, 02:11 AM
  3. Replies: 4
    Last Post: 09-27-2010, 03:24 AM
  4. phone stuck in BootLoader?
    By hyperx2002 in forum Droid X Help
    Last Post: 09-24-2010, 08:11 AM
Droid 2 Stuck in bootloader
Droid X bootloader 30.03
droid 2 global stuck in bootloader
droid stuck on bootloader
droid x bootloader screen
droid x goes straight to bootloader
droid x stuck bootloader
droid x stuck in bootloader
droid x stuck in bootloader mode
droid x stuck on bootloader
