Droid X 2.1 rooted and renamed 12 apps. unrooted to updated to 2.2..problems
This is a discussion on Droid X 2.1 rooted and renamed 12 apps. unrooted to updated to 2.2..problems within the Droid X Rooted Issues forums, part of the Droid X Rescue Squad category; Hi - Previously I had rooted my droid x and renamed the follow .apk(s) to .bak(s) (cmas, statuswidget, vpnservices, nluetoothdun, mynet, socialshare, cardock, workcontacts, blockbustet, ...
Thread: Droid X 2.1 rooted and renamed 12 apps. unrooted to updated to 2.2..problems
    Decado's Avatar
    13728
    Hi -
    Previously I had rooted my droid x and renamed the follow .apk(s) to .bak(s) (cmas, statuswidget, vpnservices, nluetoothdun, mynet, socialshare, cardock, workcontacts, blockbustet, bluettoth, stickynotewidget, newswidget, skype_mobile.live, amazonmp3, zipaligned, magicsmokewall, quickcontactwidget, redding-7648). I was having problems updating to 2.2 and before reading I unrooted thinking that would fix my issue. Now I don't seem to be able to re-root my phone or rename the .bak files to .apk. Any have ideas how to fix this? I haven't tried a factory reset since I was afraid it would brick it with those .apk(s). Any help would be appreciated.
    Points: 27,939, Level: 98
    Abe21599's Avatar
    Ohio
    4,864
    459 times
    you need to figure out what apps your missing and put them back on. the update wont work until you do so.
    http://www.chadhaney.com/droidXDefault/604/
    Decado's Avatar
    13728
    Thanks. how can i put all the default apps back into system/app folder?
    Abe21599's Avatar
    Ohio
    4,864
    459 times
    well if you lost/dont have root, you need to use adb
  1. Apps for Your Rooted Droid X
    By taypotts in forum Droid X Apps
    Last Post: 08-10-2011, 07:52 PM
  2. Replies: 0
    Last Post: 09-30-2010, 11:28 AM
  3. how do i remove apps now that im rooted?
    By medicscott in forum Droid X Help
    Last Post: 08-04-2010, 12:51 AM
  4. Cool stuff to do with an UNrooted DROID X?
    By bmwnick in forum Droid X Hacks
    Last Post: 07-25-2010, 01:09 AM
  5. Cool stuff to do with an UNrooted DROID X?
    Last Post: 07-25-2010, 12:38 AM
android rename my apps root
apps needed for droidx update
apps needed for update on droid x
can you rename apps droid
droid x rename apps
how do i rename apps on droid 2
how to rename app on rooted android
rename amazon mp3 app droid x
rename apps on rooted droid
rename apps root
rename icon droid
rename icons android 2.2
root droidx 2.1
rooted droid X apps
update rooted droid x from 2.1
