Still charging. Prob been a lil over an hour. When do you think it will be at 70%. Also, say I didnt have access to a USB dfrive or burner. What are my options then? I have Linux OS downloaded from link. His OS is Windows7.
This is a discussion on HELP! Deleted build.prop and rebooted. within the Droid X Rooted Issues forums, part of the Droid X Rescue Squad category; Still charging. Prob been a lil over an hour. When do you think it will be at 70%. Also, say I didnt have access to ...
Will i have all my SD apps, music, contacts, etc. after SBF?
Sorry we haven't gotten back to you...where are you at with it now?
If you can't burn to a disc or usb drive, you can try this...SBFboot - the easy way to sbf
You can also try the old school way with RSD lite, but you may run into more issues...guide here: Complete Droid X .sbf Flashing Guide
Either way you try, let us know how it goes or if you have any questions/issues...
To answer your other question, it will wipe everything on your internal memory such as apps, but your contacts should either be backed up with google or backup assistant. Apps sometimes will automatically restore when you sign into the market, but you may have to redownload them. Your SD card won't be affected, so your music, etc. will still be there.
You said that you installed TiBu, did you actually then backe up your apps? If so then you can restore apps from there...purchased ones will automatically download from the market, sd card won't be touched and if your contacts are associated with your gmail account then you will just re snyc.
I attempted second SBF method. Got to Linux command screen pressedb 1 for SBF, said waiting for phone, for about 30 min. I attempted to change USB it was connected to but nothing...? Plz help.
UPDATE, FIXED!!!
Sorry for the delay. I wasnt in bootloader. Followed instructions afte download. Really simple. Back to Stock gingerbread. Thanks for the help. How can I root my DX again, Gingerbreak 1.2 wont work.
Right here
[ROOT][HOW TO] Win/Linux/OS X [Latest DX .602/.605]
