Help. Remove superuser and unroot on droid x 2.2
This is a discussion on Help. Remove superuser and unroot on droid x 2.2 within the Droid X Rooted Issues forums, part of the Droid X Rescue Squad category; I rooted my droid x back when it first came out and then upgraded to 2.2 without unrooting. i had some problems with it like ...
Results 1 to 6 of 6
Thread: Help. Remove superuser and unroot on droid x 2.2
    X Lurker Con's Avatar
    42968
    Jul 2011
    Angry Help. Remove superuser and unroot on droid x 2.2
    I rooted my droid x back when it first came out and then upgraded to 2.2 without unrooting. i had some problems with it like camera not working and it not allowing me to get newer updates. i did a factory reset and took my phone into verizon because it wont update (probably cause its rooted or something). Anyway i didnt notice till i got home that i still have the superuser app, and now i have to ship verizon my phone in 5 days. I have tried using Z4root to reroot and unroot it, but its still there and i dont know how to get rid of it. Plz help. I dont want to send them a phone that was obviously messed with.
    RS Team Leader
    Points: 25,439, Level: 96
    Level completed: 9%, Points required for next Level: 911
    Overall activity: 15.1%
    popcenator's Avatar
    21238
    Omaha, NE
    8,255
    177 times
    SBF to completely and easily remove all traces of root.
    Here's the easiest method.
    SBF
    on the move..
    Points: 67,578, Level: 100
    Overall activity: 16.2%
    HarleyDude's Avatar
    19213
    Philly area
    8,191
    460 times
    As Pop said, SBF is the most thorough way.
    Simpler is to root with z4, then use a file explorer with root capabilities (esfile or supermanager both free in the market) and go to /system/app, scroll down to find superuser.apk, long press it and select delete. reboot, unroot, uninstall z4. This will be fine if you have not installed clockwork recovery
    Ok, I have NEVER done any of this rooting business before. I purchased a phone from someone who rooted it and I need it unrooted. I'm not sure what the purpose of it is... but I think I like a stock phone. When I clicked the link above, it went to a page that shows how to instal a root (I think). You'll have to talk me through this. SERIOUSLY stupid when it comes to this stuff. HELP PLZ?!
    Points: 26,429, Level: 97
    Level completed: 8%, Points required for next Level: 921
    Overall activity: 47.2%
    7,093
    338 times
    Go to settings - about phone and tell us your android and system version.
    Sent from my Razr HD using Xparent Cyan Tapatalk 2
    Points: 16,528, Level: 82
    Level completed: 36%, Points required for next Level: 322
    Overall activity: 99.9%
    Activity Award
    sd_shadow's Avatar
    56013
    South Dakota
    2,448
    284 times
    Quote Originally Posted by jamiesmithphotos View Post
    rooting does nothing to phone, it gives you access to system files, that's it
    if system files were changed/ removed or a custom rom was flashed you need to flash a .sbf file
    Using RSD Lite to flash a .SBF to restore (Stock Rom)
    or DX (MB810) ezSBF 2.3.4/4.5.621
    after flashing the sbf, phone will be unrooted
  1. Remove superuser icon in nonrooted GB
    By TruePCs in forum Gingerbread Help
    Last Post: 08-23-2011, 04:09 PM
  2. Replies: 4
    Last Post: 06-09-2011, 01:17 PM
  3. Superuser app reappears even after unroot.
    By royolpunk in forum Droid X Help
    Last Post: 01-01-2011, 04:14 PM
  4. Remove Superuser Permissions
    By daj0kker in forum Droid X Hacks
    Last Post: 11-07-2010, 07:26 PM
  5. Replies: 7
    Last Post: 07-16-2010, 07:55 PM
how to remove superuser app
how to remove superuser from droid
how to remove superuser from droid x2
remove superuser android
remove superuser droid x
remove superuser droid x2
removing superuser from droid x
unroot droid x
