How to get out of this brick?
This is a discussion on How to get out of this brick? within the Droid X Rooted Issues forums, part of the Droid X Rescue Squad category; Well, I was on the FIRST LEAK of Gingerbread for the DX. Everything was running fine, but I wanted to try out a new rom ...
Results 1 to 10 of 10
Thread: How to get out of this brick?
    bd1212's Avatar
    18703
    11
    Well, I was on the FIRST LEAK of Gingerbread for the DX. Everything was running fine, but I wanted to try out a new rom for gingerbread that was based on the NEWEST LEAK (.588), but in order to do so, I had to sbf back to 2.3.340.
    So, I backed up my DX's current state, plugged it into my PC, shut it off, booted into the bootloader, opened RSD Lite 4.8, selected the appropriate SBF file, and clicked start.
    Everything started off without a problem, but a few seconds later, I checked on the RSD Lite and it said "Error: Failed the flashing process."
    I then googled around for an answer. Answers that I found said to try to restart the sbf and that it would usually fix it. I then did that, but after doing so, I got a new error. The new error states "Failed flashing process. Failed flashing process. Error getting subscriber unit information."
    What do I do now? I'm completely stuck and do not know what to do. I have sbf'd in the past and NEVER had any problems, so I'm quite calm at the moment.
    Please help as I would like to get this fixed quickly!
    Thanks in advance.
    Moderator
    Points: 25,450, Level: 96
    Frequent Poster
    mikeinrichmond's Avatar
    9010
    Richmond, Va
    7,668
    392 times
    First, turn off your phone now, it won't charge in bootloader mode, so save your battery until you get everything setup. Your answer is here, the easiest way to SBF your phone:
    http://www.droidxforums.com/forum/dr...tml#post267721
    bd1212's Avatar
    18703
    11
    Quote Originally Posted by mikeinrichmond View Post
    I think I just fixed it. o_o
    Before you replied, I had pulled the battery and put it back in and upon doing this, my phone immediately -- without me touching it -- booted back into the bootloader screen and said I was on bootloader version 30.03 (before it said I was on bootloader version 30.04). This seemed strange to me, but I shrugged it off. Under the version number, it said "Code Corrupt", and under that it said "Battery good" or something along those lines and then under that it said "ok to program". I then restarted the sbf and now it's going through the process perfectly.
    Moderator
    Frequent Poster
    9010
    Richmond, Va
    7,668
    392 times
    Glad you got it going..
    Quote Originally Posted by bd1212 View Post
    Wish i had a second battery, bc mines already saying Battery Low Cannot Program
    Points: 6,623, Level: 53
    Level completed: 37%, Points required for next Level: 127
    Overall activity: 5.9%
    casper55117's Avatar
    56375
    Mar 2012
    minnesnowda
    1,008
    12 times
    Quote Originally Posted by hjustin2 View Post
    you can charge it by cutting a usb twisting the two red wires together and the two black wires together and holding it to the battery for like 5 min should be enough juice to sbf. just dont touch the black to the red
    Banned
    Points: 9,438, Level: 65
    Level completed: 30%, Points required for next Level: 212
    DroidlynnXDoes's Avatar
    56858
    Mar 2012
    In a world that doesn't
    3,118
    16 times
    Quote Originally Posted by casper55117 View Post
    Does that make it charge faster? And which end is supposed to be cut?
    Points: 26,638, Level: 97
    Level completed: 29%, Points required for next Level: 712
    Overall activity: 62.2%
    Nemo aeternamn's Avatar
    37333
    Mo-ab
    7,738
    165 times
    That's not recommend because it can damage the battery or the phone...
    "I'll get you my little pretty... and your little dog todo too"
    "I don't even have a little dog todo"
    Post Script:
    Nemo Aeternamn Wallpapers
    Points: 45,910, Level: 100
    DirtyDroid's Avatar
    28665
    Upstate,NY
    14,576
    384 times
    Quote Originally Posted by Nemo aeternamn View Post
    +100..to that
    Sent from my DROIDX
    Banned
    56858
    Mar 2012
    3,118
    16 times
    I'm glad I didn't do that. I don't want my sweet little X to get damaged. I love my X too much to much to let anything happen to her
  1. is it possible to brick
    By jmartinez748 in forum Droid X General Discussion
    Last Post: 04-04-2011, 05:18 PM
  2. Did I brick my D X?
    By brandonXabbott in forum Droid X Rescue Squad
    Last Post: 03-23-2011, 05:41 AM
  3. Was on 2.2.340 SBF'd to 2.2.315...brick?
    By dard12 in forum Droid X Hacks
    Last Post: 02-08-2011, 06:47 PM
  4. Did I Brick My DX
    By aZZleZZmonkieZ in forum Droid X Help
    Last Post: 12-10-2010, 11:28 AM
  5. 2.2 to 2.1 brick?
    By yellosnomonkee in forum Droid X Rescue Squad
    Last Post: 10-26-2010, 06:50 PM
error getting subscriber unit information
error getting subscriber unit information droid x
error: error getting subscriber unit information.
get droid 2 out bootloader mode
how to get droid x out of bootloader
how to get droid x out of bootloader mode
how to get out of bootloader mode
how to get out of bootloader mode droid 2
how to get out of brick mode
how to get phone out of bootloader mode
