[ROM] Zero Blur! Zero Lag! rubiX Focused 1.0
This is a discussion on [ROM] Zero Blur! Zero Lag! rubiX Focused 1.0 within the Droid X ROMs forums, part of the Droid X Development category; Originally Posted by Fil Are you supposed to mount system prior to install? I just downloaded from the link in the OP, then went to ...
Page 3 of 68 FirstFirst 1 2 3 4 5 13 53 ... LastLast
Results 21 to 30 of 675
Like Tree65Likes
Thread: [ROM] Zero Blur! Zero Lag! rubiX Focused 1.0
  1. #21
    Points: 999, Level: 16
    Level completed: 99%, Points required for next Level: 1
    1sheldon1's Avatar
    15157
    12
    Quote Originally Posted by Fil View Post
    I just downloaded from the link in the OP, then went to Install ROM from SD Card in ROM Manager (be sure you bootstrap recovery first). I checked Wipe Data and Cache (I didn't back up my current ROM because I backed up the one I had before 0.5, and I had only been running 0.5 for about twenty minutes), then OK to boot into recovery to continue installation. Before I even realized it, I was already back to the big green android screen.
  3. #22
    Developer
    Developer
    1000 Experience Points500 Experience Points250 Experience Points100 Experience Points7 days registered
    drod2169's Avatar
    11469
    Tampa, Florida
    250
    159 times
    Quote Originally Posted by gizram84 View Post
    I am running the original leaked 2.2 with FlyX, do I need to format anything or should I install this exactly as your instructions indicate?
    Once I install RubiX 1.0, will I be able to SBF back to 2.1, or will I be considered on the 2.2 OTA (requiring a 2.2 SBF) ?
    It will not be considered 2.2 ota, I can't replace your bootloader/kernel/baseband
    You need to wipe data/cache. That is all.
  4. #23
    Developer
    Developer
    drod2169's Avatar
    11469
    Tampa, Florida
    250
    159 times
    Quote Originally Posted by 1sheldon1 View Post
    Did it install? New boot animation and vanilla look.. you'll know
  5. #24
    1sheldon1's Avatar
    15157
    12
    Quote Originally Posted by drod2169 View Post
    It installed unbelievably fast!
  6. #25
    Points: 1,405, Level: 21
    infounlim's Avatar
    304
    5
    Does this come with Visual VM? If not how should it be installed?
  7. #26
    KoreaZ's Avatar
    11216
    8
    I know with rubix focued 0.5 i applied the revolution theme and it worked perfect. Can i assume the same with 1.0?
  8. #27
    Developer
    Developer
    drod2169's Avatar
    11469
    Tampa, Florida
    250
    159 times
    Quote Originally Posted by KoreaZ View Post
    No. The framework is heavily modified. This was answered on the 1st on 2nd page as well Themes cannot be used on this yet.
  9. #28
    Developer
    Developer
    drod2169's Avatar
    11469
    Tampa, Florida
    250
    159 times
    Quote Originally Posted by infounlim View Post
    via market
  10. #29
    Points: 3,280, Level: 35
    Level completed: 54%, Points required for next Level: 70
    Overall activity: 0.7%
    omnicious's Avatar
    1341
    525
    14 times
    This installs over OTA 2.2 right?
  11. #30
    Developer
    Developer
    drod2169's Avatar
    11469
    Tampa, Florida
    250
    159 times
    Quote Originally Posted by omnicious View Post
    This installs over anything.. it wipes your system partition and completely replaces it with mine. Just make sure you wipe data/cache
  1. [ROM] rubiX Focused 0.3
    By drod2169 in forum Droid X ROMs
    Last Post: 01-25-2011, 10:46 AM
  2. rubiX questions
    By tx3 in forum Droid X ROMs
    Last Post: 10-20-2010, 08:26 PM
  3. RubiX over BGX
    By Uncle Chan in forum Droid X ROMs
    Last Post: 10-18-2010, 08:49 AM
  4. Rubix Focused 0.5 and SMS question
    By Phildo in forum Droid X ROMs
    Last Post: 10-17-2010, 09:56 PM
  5. Replacing Boot Animation In Rubix Focused 0.3
    By Gangsta4evr in forum Droid X ROMs
    Last Post: 10-10-2010, 09:34 AM
android mediarecorder stop failed -1007
android mediarecorder stop failed 1007
android stop failed 1007
droid x camera lag
e syntax error in update script droid x
e:syntax error on droid 2
mediarecorder stop 1007
rubix focused screenshots
rubix rom droid x screenshots
zerolag redmine
