This is a discussion on [ROM] Zero Blur! Zero Lag! rubiX Focused 1.0 within the Droid X ROMs forums, part of the Droid X Development category; Originally Posted by 1sheldon1 I have 1.0 running now and I'm extremely impressed with the look. I'm also loving the speed. It seems to be ...
Are you supposed to mount system prior to install?
I am running the original leaked 2.2 with FlyX, do I need to format anything or should I install this exactly as your instructions indicate?
Once I install RubiX 1.0, will I be able to SBF back to 2.1, or will I be considered on the 2.2 OTA (requiring a 2.2 SBF) ?
