2.2 OTA question please
This is a discussion on 2.2 OTA question please within the Droid X ROMs forums, part of the Droid X Development category; So my wife and I both have droidx's Mine: rooted/rubix.03/Nextheme Hers; OTA 2.2 Froyo update She wants her phone like mine.. Because the ota update ...
Results 1 to 8 of 8
Thread: 2.2 OTA question please
    Points: 4,966, Level: 45
    Level completed: 8%, Points required for next Level: 184
    Roooler's Avatar
    1448
    Cedar City, Utah
    414
    40 times
    She wants her phone like mine.. Because the ota update blows on her phone and force closes everything!.
    She asked me to root it today and install the rubix.03 rom when I did my phone it was the 2.1 do I'm not totally familiar with the steps for 2.2..
    Correct me if I'm wrong PLEASE.
    FIRST: Root the phone
    Second: DL boot strap
    Third: make a back up of current state via boot strap
    Fourth: download rom place on sd card rebooy into recovery and yada yada yada
    Am I missing something here that I just don't see?
    Points: 27,939, Level: 98
    Abe21599's Avatar
    Ohio
    4,864
    459 times
    if rubix is compatible with OTA 2.2 (idk), then yes, those steps are how u wanna go about it.
    just make sure u DL and flash the bootstrap. and that u meet all the requirements for rubix
    Gunkle's Avatar
    868
    52
    Quote Originally Posted by Roooler View Post
    That is correct. the important steps are to format system, cache and data
    They are in the instructions for the rom. YOU MUST DO THEM or you will have problems they would be part of your fourth step. Follow all directions from the rom's page and you wont have issues.
    remember to use the clockwork recovery from the bootstrap to do the backup and to install the rom. Not the the stock recovery.
    also to clarify something you said. You had to have been on 2.2 before you installed rubix on your phone it needs the kernel from 2.2 You must have been on one of the leaks if you didn't use the OTA. Just wanted to say that so someone doesn't see that and try from 2.1. big problems will follow if tried.
    Roooler's Avatar
    1448
    Cedar City, Utah
    414
    40 times
    You are correct sorry about that.
    I was running the leaked 2.2 then went to Flyx then to Rubix i should have clarified that in my Original post.
    Currently i am performing the Back up on her phone... then going to load up some Rubix thanks guys appreciate the responses
    Roooler's Avatar
    1448
    Cedar City, Utah
    414
    40 times
    So i flashed everything over and got everything setup perfectly.. However one Major problem..
    My wifes Contacts are not Syncing.. I know that RUbix does not have BLUR therefore it wont automatically SYNC facebook contacts etc.. however i did edit the socialmessaging.apk into the system and permissioned it correctly.. still nothing is showing it (it has been said to take a couple days to take effect)
    Can i Restore the Backup of the Rooted OTA 2.2 on her phone.. copy her contacts to her gmail or my desktop.. then Restore the Rubix.03 and load her contacts in? or is it not that simple?
    Also as stated Backup assistant does not work with RUbix.03
    Gunkle's Avatar
    868
    52
    yes. restore
    sync contacts with the gmail account on her phone. give it some time to do this
    then redo. You could even backup what you have now before restoreing then when its all sync'd you could restore that backup and not go through the install again. then set the contacts to sync in rubix and your good. If that makes sense to you. I think we are saying the same thing. so yes
    chkmate's Avatar
    9625
    17
    Just want to clarify something. RubiX does work on the DX 2.2 Official OTA?
    Points: 1,054, Level: 17
    Level completed: 54%, Points required for next Level: 46
    mugsy77's Avatar
    14402
    24
    Quote Originally Posted by chkmate View Post
    Yuppers. Here is rubiX's thread where most of your questions are probably already answered: http://www.droidxforums.com/forum/dr...uys-crazy.html
    Easy to miss because of the title at the moment In this thread you'll find both Blurry and Focused ROMS (current)
  1. Root question (simple question looking for a simple answer)
    By supahrob in forum Droid X General Discussion
    Last Post: 08-17-2010, 07:56 PM
  2. More of a contract question than a Droid x question
    By Gixxer in forum Droid X General Discussion
    Last Post: 07-23-2010, 06:36 AM
what does socialmessaging.apk do?
