CyanogenMod 11 (Unofficial) For Droid X-March 2014
This is a discussion on CyanogenMod 11 (Unofficial) For Droid X-March 2014 within the Droid X ROMs forums, part of the Droid X Development category; As posted By m.ksy @ CyanogenMod 11 (Unofficial) - 3/31/14 - Droid X Development - RootzWiki Mod Type:: ROM Requires Root:: Yes Apply In:: TWRP ...
Results 1 to 10 of 12
Thread: CyanogenMod 11 (Unofficial) For Droid X-March 2014
    Points: 18,799, Level: 86
    Level completed: 90%, Points required for next Level: 51
    Overall activity: 88.9%
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    As posted By m.ksy
    @CyanogenMod 11 (Unofficial) - 3/31/14 - Droid X Development - RootzWiki
    Apply In:: TWRP Recovery Optional:: Includes Recovery (Safestrap, TWRP Recovery)
    Android Version:: 4.4.2 (KitKat) Source:: http://github.com/MotoDX-CM11
    Actual version: 03.31 (cm-11-20140331-UNOFFICIAL-shadow)
    Screenshots
    Supported langs: en_US en_GB en_IN fr_FR it_IT de_DE es_ES hu_HU uk_UA zh_CN zh_TW ru_RU nl_NL se_SV cs_CZ pl_PL pt_BR da_DK ko_KR
    el_GR ro_RO iw_IL ar_EG
    List of known issues
    • random hot reboots for some users
    • video rec 480p only
    • GPS doesn't work, only AGPS
    DownloadsMEGA -Mediafire -GoogleDrive
    Installation
    • If you on custom ROM (CM, MIUI, LiquidICS, etc.) goto step 6.
    • Download Droid 2 Recovery Bootstrapper CWM 5.0.2.0 and Framaroot.apk to sdcard.
    • On phone: Settings->Applications(Enable Unknown sources)->Development->Enable USB Debugging.
    • Install Framaroot.apk, launch it and select "Gimli", reboot phone.
    • Install Droid2RecoveryBootstrap_CWM5.0.2.0.apk, launch it, select "Bootstrap Recocery", grant Superuser access and reboot phone.
    • Download twrp_cm11_dx.zip, latest gapps and ROM to sdcard.
    • Reboot phone into CWM Recovery or if you on stock firmware launch Droid X Bootstrapper and press "Reboot Recovery".
    • In CWM choose wipe data/factory reset (this will completly delete all your data on phone except sdcard), then install zip from sdcard and select twrp_cm11_dx.zip.
    • Reboot system and immediately enter the bootmenu (press vol- on blue LED).
    • (It's touch) Recovery -> Team Win Recovery.
    • In TWRP choose Install and select ROM, then slide, after install Reboot -> System.
    • Wait while phone boot up, complete the setup, then reboot phone.
    • On screen with android on red background press menu hardware key, then choose Install and select gapps.
    • Reboot -> System.
    Thanks
    • The entire CyanogenMod team for the ROM
    • Quarx and CyanogenDefy team
    • Aaahh for port the first version of TWRP Recovery
    • Everyone who tested and provided feedback
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    Quote Originally Posted by m.ksy
    Changelog:
    cm-11-20140607-UNOFFICIAL-shadow
    • CM repo sync (Android 4.4.3)[/*]
    • Quarx's repo sync[/*]
    • some fixes for system stability[/*]
    cm-11-20140523-UNOFFICIAL-shadow
    • CM repo sync (lot of changes)[/*]
    • add ffmpeg support[/*]
    • cap max CPU frequency to 1 GHz as soon as possible[/*]
    • add Swedish[/*]
    • decrease min_free_kbytes to 10240[/*]
    • JustArchi's ArchiDroid Optimizations V2[/*]
    • prebuilt Google Now with gapps 5-22[/*]
    • better USB OTG support[/*]
    cm-11-20140509-UNOFFICIAL-shadow
    • CM repo sync[/*]
    • possible fix for different apn: data, mms (not tested)[/*]
    • fixed com.google.android.location FC (require updated gapps 5-5 or up)[/*]
    • add missed themes settings icons[/*]
    • some rework for camera HAL (for future changes)[/*]
    • add kpanic partition support[/*]
    • custom eri for some carriers (require changed ro.cdma.home.operator.numeric=mccmnc in build.prop)[/*]
    • voicemail number moved into build.prop (ro.cdma.vm.number)[/*]
    cm-11-20140505-UNOFFICIAL-shadow
    • CM repo sync[/*]
    • restored SVOX, PicoTts[/*]
    • fixed com.android.incallui FC[/*]
    • freeup ~90 Mb space on system partition[/*]
    • fixed vibration in recovery[/*]
    • disable menu, back and search buttons for wake phone[/*]
    cm-11-20140502-UNOFFICIAL-shadow
    • CM repo sync (landscape mode for call UI, etc.)[/*]
    • backported interactive gov from 3.4 kernel (for test)[/*]
    • fixed batt charge counter in recovery[/*]
    • in recovery battery charging support (can be used for battery calibration)[/*]
    • common system cleanup[/*]
    • fix for new version of Netflix[/*]
    • increase min_free_kbytes to 20480[/*]
    • some performance tweaks[/*]
    • returned to the previous wallpaper[/*]
    cm-11-20140424-UNOFFICIAL-shadow
    • CM repo sync[/*]
    • fixed GPS[/*]
    • option in BT settings to accept receiving any files[/*]
    • indicate connected headset by icon in statusbar[/*]
    • hide mobile plan (GSM) item in network settings[/*]
    cm-11-20140422-UNOFFICIAL-shadow
    • CM repo sync[/*]
    • fixed network modes in data settings (2G(CDMA), 3G(EVDO), auto)[/*]
    • fix for phone randomly turns on after shutdown[/*]
    • deleted Defy's stuff[/*]
    • fix for Netflix[/*]
    • fixed mbm and mbm loader version[/*]
    • proper fix for sensors (accelerometer, etc.)[/*]
    • fix for 143 GPIO (audio) problem[/*]
    • probable fix for OTG reset[/*]
    • fixed kim driver[/*]
    • system stability improvements[/*]
    cm-11-20140416-UNOFFICIAL-shadow
    • CM repo sync (new theme engine, etc.)[/*]
    • fix in call audio switching (BT also, but only scratch may hear)[/*]
    • Defy's files cleanup[/*]
    • deleted some GSM stuff[/*]
    • cap battery level at 100%[/*]
    cm-11-20140410-UNOFFICIAL-shadow
    • CM repo sync[/*]
    • fix crash on camera close[/*]
    • fix widescreen photo autofocus (6Mp)[/*]
    cm-11-20140409-UNOFFICIAL-shadow
    • CM repo sync[/*]
    • fix stuck on reboot[/*]
    cm-11-20140407-UNOFFICIAL-shadow
    • CM repo sync[/*]
    • add egl tweaks[/*]
    • Defy Parts -> Additional settings[/*]
    • fix 720p video record (6Mp autofocus broken again)[/*]
    • set high-end graphics enabled by default[/*]
    • increase video quality[/*]
    • removed Stk.apk (SIM toolkit)[/*]
    • no need to reboot before install gapps (3-22 or later)[/*]
    Fixed:
    • data connection (EvDo, 1xRTT)[/*]
    New:
    • changed OC method (Milestone OC)[/*]
    cm-11-20140329-UNOFFICIAL-shadow
    Fixed:
    • volume buttons for zoom in camera app[/*]
    • unmapped key error[/*]
    • unknown carrier[/*]
    • focus(camera) button sometimes works like back button[/*]
    cm-11-20140328-UNOFFICIAL-shadow
    Fixed:
    • CDMA[/*]
    • reboots[/*]
    New:
    • TWRP Recovery 2.7.0.0[/*]
    • stability improves[/*]
    cm-11-20140326-UNOFFICIAL-shadow
    Fixed:
    • 8Mp photo quality for stock camera[/*]
    New:
    • some work to increase battery life[/*]
    cm-11-20140325-UNOFFICIAL-shadow
    Fixed:
    • Camera
      • video: 480p[/*]
      • photo: 5M - will be fixed soon[/*]
    cm-11-20140324-UNOFFICIAL-shadow
    Fixed:
    • Torch/led flash[/*]
    New:
    • CM repo sync (KK 4.4.2_r2)[/*]
    • Reduce LockClock size (free up some memory on system partition)[/*]
    cm-11-20140322-UNOFFICIAL-shadow
    Fixed:
    • Vibration[/*]
    • FM (that I broke in 03.20 :emoji_u1f604:)[/*]
    New:
    • CM repo sync (new wallpaper from them and other things)[/*]
    • Stability improvements[/*]
    • A little closer to make CDMA working (modem detected now, but can't init)[/*]
    cm-11-20140320-UNOFFICIAL-shadow
    Fixed:
    • Proximity sensor[/*]
    • Inverted compass[/*]
    cm-11-20140317-UNOFFICIAL-shadow
    Fixed:
    • GPS[/*]
    • Bluetooth[/*]
    • FM Radio[/*]
    cm-11-20140314-UNOFFICIAL-shadow
    Fixed:
    • safety information in «About phone»[/*]
    • chargeonly mode[/*]
    • bootstrap image directory[/*]
    • proper removal of battery stats[/*]
    • remove export path in logwrapper[/*]
    New:
    • more network modes (for future)[/*]
    • permissions for apps[/*]
    • low RAM enabled by default[/*]
    • reduce System app size[/*]
    • some new props in build.prop[/*]
    cm-11-20140312-UNOFFICIAL-shadow(new)
    Fixed:
    • accelerometer inverted axis[/*]
    • rotation sensor inverted axis[/*]
    Fixed:
    • screen rotation[/*]
    cm-11-20140307-UNOFFICIAL-shadow
    Fixed:
    • data mount on system start[/*]
    - apps can be installed normally
    - no more wipe data on reboot
    • data mount in TWRP recovery[/*]
    • adb in bootmenu (no bootmenu - no problem )[/*]
    New:
    • safestrap instead of bootmenu.[/*]
    cm-11-20140301-UNOFFICIAL-shadow
    • minor version[/*]
    • latest version with bootmenu[/*]
    cm-11-20140227-UNOFFICIAL-shadow (deleted)
    • unstable[/*]
    • data partition mount problem[/*]
    • wipe data after each reboot[/*]
    Edited by m.ksy, 07 June 2014 - 12:14 PM.
    GoCliffGo05 likes this.
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    Preformence Guide:
    • Airplane Mode
    • About phone --> Click Build number 8 times Necessary for the two below
    • Developer Options --> At the Bottom: Select runtime --> ART (its truely an art)
    • Performance --> Force high-end graphics(optional)
    • Aero Control (play store) -->Menu --> CPU Performance --> Govenor Settings --> smartass
    • Aero Control (play store) --> Menu --> GPU Control --> GPU Control
    • Aero Control (play store) --> Menu --> Memory Tuning --> Low Memory Option
    • Aero Control (play store) --> Menu --> Memory Tuning --> IO Scheduler --> deadline
    • Aero Control (play store) --> Settings --> Reboot check mark...
    • Clear cahce from twrp
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    that's what happens when you use tapatalks dark theme, looks fine on browser
    Sent from my XT894 using Tapatalk
    Points: 2,450, Level: 29
    Level completed: 50%, Points required for next Level: 150
    250 Experience Points500 Experience PointsTagger Second Class31 days registered7 days registered
    tripperdan99's Avatar
    31995
    7
    wow, thanks! I'm trying to decide if I should install CM7, CM9 or now this, CM11. We got rid of Vzw, so being on pre-paid we have to make the phones last a little longer. Plus the DX is a great phone to give a kid for their first phone.
    Appreciate the efforts on this classic droid
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    Depends on how it will get used, and what you want.
    read some here CyanogenMod 11 (Unofficial) - 6/20/14
    Liquid 2.1 is also a very good rom
    LiquidICS v2.1A [UNOFFICIAL] - 3/12/14
    First of all, thank you for your work. You seem to be the person to go to when it comes to the Droid X and X2. I'm currently running eclipse v2.3 on my X2. I have a couple of questions.
    1) Will this rom work with the X2?
    2) If not, what rom would you recommend?
    3) My carrier is Page Plus cellular, will flashing a new rom effect my account with them?
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    Quote Originally Posted by bigsnow81 View Post
    1. No
    2. Eclipse 2.3
    3. No
    There are no new ROMs for the dx2
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
  1. Droid x2 Cyanogenmod help
    By bryanv7 in forum Droid X2 Hacks
    Last Post: 11-26-2012, 09:16 PM
  2. Replies: 2
    Last Post: 10-01-2011, 09:01 PM
  3. CyanogenMod 7 for Droid X
    By Keuka79 in forum Droid X ROMs
    Last Post: 05-21-2011, 09:56 PM
  4. Unofficial Android 2.3 with new Motoblur reaches Droid X
    By JimMariner in forum Droid X News
    Last Post: 04-04-2011, 08:34 PM
  5. Droid X - End of life is here - March 31st, 2011
    By DebianDog in forum Droid X General Discussion
    Last Post: 08-25-2010, 04:11 PM
cm-11-20140326-unoff
descargar cm-11-20140326-unoff
droid x cyanogenmod 11
droid x twrp
twrp 2.7 cm11 dx.zip
twrp 2.7 cm11 dx.zip-mirror
twrp cm11 dx.zip
twrp droid x
twrp dx.zip
twrp for droid x
