hello everyone,
I am currently running android 4.0.1 with EncounterICSX Beta 3. According to ROM Manager, I am have Clockworkmod Recovery 5.0.2.0 flashed. I want to flash CM9 which I have downloaded and on my SD card.
From ROM Manager, I can not reboot into recovery. I also cannot install rom from sd card. Both of these simply reboot my phone. I can't boot into recovery with Droid 2 Bootstrapper. I tried manually booting into recovery by holding power and volume down but that did not work.
I think flashing an older version of CWM might fix the problem, but I couldn't figure out how.
pre-thanks for the help.
