tried flash 2 different ROMS and got stuck in bootsreen
i followed instructions from liberty 2.0 and wipe data, factory, cache divlak then install zip successful installed then stuck on "liberty" so i SBF back to .340 then try Apex with .602 built in and do same thing then stuck on "google" what have i done wrong?
so im start all over what i have right now is SBF back to .340 and z4root and use Droid 2 bootstrap so tell me what to do
-should i use different kind bootstrap ?
01-27-2012 08:58 AM
Originally Posted by
wake4x4ptball
At this point I suggest taking the OTA updates to get to .605. THEN you can flash apex, or liberty, again. .602 and .605 are more-or-less interchangeable. .340 is not. That was the latest problem. You will need the zergrush root or Pete's root tool to root GB. D2 bootstrap is what you want to flash with.
Another option is to use 1KDS Linux sbf with root iso. Very easy. Just read the instructions carefully a few times first.
(This is a tapa sig) r...e...a...d
my droid X is deactivated cuz i hane nexus galaxy now i tried ota on droid X but it wont allow me to click system upgrades im using wifi on droid X only so i guess i need find a way to upgrade to .605
i SBF to .340 then can i SBF again to .602 wipe data again or just add on?
wake4x4ptball
You need to sbf to 602, then root with d3 one click, install d2 bootstrap, then install the rom.
Doing wipes like the rom install tells you.
Running with MIUI
Droid X powered by
MIUI or whatever rom is new and booting off of Boot Manager
I've got my SBF badge.
