3G/1X does not work in Liberty 2.0
This is a discussion on 3G/1X does not work in Liberty 2.0 within the Droid X ROMs forums, part of the Droid X Development category; I enable the setting in notification bar (up and down arrow). But the 3G icon is still not shown. Any advise? Thanks. Update: Solved. Replace ...
Results 1 to 7 of 7
Thread: 3G/1X does not work in Liberty 2.0
    Points: 54, Level: 1
    Level completed: 8%, Points required for next Level: 46
    zhou13's Avatar
    54151
    Jan 2012
    Update: Solved. Replace pppd-ril.options. I need this because I'm using China Telecom's network. I never know I should use its own pppd-ril.opens. file
    Themer
    Points: 9,979, Level: 66
    Level completed: 83%, Points required for next Level: 71
    Overall activity: 86.0%
    BHuber09's Avatar
    34670
    Atlantis
    3,337
    60 times
    Airport mode then if that doesn't work *22891
    FreeMyMoto!!!
    FreeMyMoto!!!
    If you need help PM me
    zhou13's Avatar
    54151
    Jan 2012
    I don't enable the Airport mode....
    RS Team Leader
    Points: 19,438, Level: 88
    Level completed: 18%, Points required for next Level: 412
    Overall activity: 44.3%
    popcenator's Avatar
    21238
    Omaha, NE
    7,802
    112 times
    A reboot usually fixes the issue.
    zhou13's Avatar
    54151
    Jan 2012
    Strangely, after rebooting, the issue still exists. How to enable 3G network in android setting? Is it background data setting? No matter whether I enable the up and down arrow or not, the background setting do not change.
    Points: 530, Level: 10
    Level completed: 60%, Points required for next Level: 20
    calsonicblu's Avatar
    35768
    I am having this same issue. I've tried *228 option 2, then option 1, then rebooted, with no luck. Tried clearing Dalvik cache next and I am still without 3G/1X. I don't know what else to try.
    Super Mod Team Lead
    Points: 29,879, Level: 99
    Level completed: 93%, Points required for next Level: 121
    Overall activity: 83.1%
    fezrock's Avatar
    29044
    Asheville-ish
    6,380
    142 times
    Make sure the Liberty download you used has a matching md5 checksum. You can use Android File Verifier or most any file explorer to check yours, then match it against one posted with the download link. If it matches, try doing only cache and dalvik wipes, and reflash Liberty. As long as you don't wipe data, you won't have to redo your setup.
    (this is a tapa sig) r...e...a...d
    "FEZ aims to create a non-threatening world rich with ambiance, a pleasant place to spend time in."
    My bootanimations My bootlogos Fantastic bootanimation tutorial!Reading, breaking, reading, and restoring
  1. does liberty 2.01 work with android 2.2 2.3.151?
    By chad362wiley in forum Droid X Rescue Squad
    Last Post: 06-03-2011, 11:18 PM
  2. Can NOT get Netflix to work for Liberty GB
    By Koopa Troopa in forum Gingerbread Development and Hacking
    Last Post: 05-19-2011, 08:32 PM
  3. Can you get HDMI to work on Liberty 2.0.1
    By rdubb in forum Droid X Audio / Video
    Last Post: 05-18-2011, 11:12 PM
  4. Will Liberty 1.5 work on Droid Pro as well?
    By jwnic in forum Droid X ROMs
    Last Post: 03-05-2011, 05:05 AM
  5. Finally got liberty 1.5 to work! :)
    By usmc7356 in forum Droid X ROMs
    Last Post: 02-17-2011, 08:33 AM
3g not working on droid
3g not working on droid x
3g setting for droid x
3g will not work iphone
change setting in pppd-ril.option to get 3g
droid x 3g liberty not working
droid x 3g not working
droid x doesnt have 3g
droid x liberty 3g
droid x will not get 3g
enable network in liberty 2.0 rom
how to change pppd-ril without root
liberty 2.0 3g issues
verizon 3g not working droid x
why doesnt 3g work on droidx
