3g mobile hotspot
Sorry if this has been asked. I have no internet right now and the mobile search sucks.
I have rooted and installed liberty 3 2.0 and was wondering if that was all I needed to run the 3g mobile hotspot undetected by Verizon. Any help would be a big thanks as I am with out internet for a week.
12-29-2011 08:01 PM
You also need to install the tether patch WugPacked GB Tether Patch [All-In-One Zips]
Ok. Thanks for the fast response, but after reading some of the comments about the disclaimer its probably not a good idea to tether my PS3 for some BF3 gaming?
I game on my tether. I feel it is no problem
Originally Posted by
douglasfamily
Check this out and it works perfect with Droid X also. All you have to do is below and you are set to go.....once all of the below is completed you are you go to go..... you do not need to turn on your hotspot just start the app and turn on/start tethering
android-wifi-tether - Wireless Tether for Root Users - Google Project Hosting
Required Settings:
Settings for wifi_tether_v3_1_pre111.apk
Device-Profile > Droid X
Setup-Method > Auto
Wifi-diriver reload > Checked
Routing fix > Checked (MAKE SURE THIS IS CHECKED)
Disable Wake-Lock > Checked
{{ WIFI TETHER: How To }}. - go here for further details and discussion of how to. Check out this forum it helps out a lot, it's not just for ThunderBolts
I take no credit for any of these. All credits goes to Android WiFi-Tether and also to Stratejaket and Santod for the write ups.
Don't forget to hit that "Thanks" or "Like" button if this helps you out. Hope I didn't step on anyone toes be directing to other forums for help and/or knowledge.
Thanks. Quick question though. Say I get this done, is there anything else that would need to done in order to stay under Big Reds radar? I have unlimited data and don't feel that I should have to pay a second fee for the same data.
Besides the link savage posted and one above, youll be good, to go
Big THANKS!
Thanks for all your guys help
