Froyo or GB
Is all the newest highly customizable roms like liberty and miui on GB or is there others? Im a little hesitant on doing the sbf to .602 to jump from miui 1.7.22 cause I've bricked a phone in the past.
Is it safe to go to - about phone - system update to get to GB?
Miui 1.7.22, rooted and oc'ed
11-22-2011 08:02 AM
It's very safe to SBF to .602, that's how you fix a brick, if you need some help with the process we can help you through it. Support for Froyo ROMs have pretty much ceased. I'd work on getting back to GB.
So I can just do an OTA system update under " about phone?"
Originally Posted by
Eleigh
No, it won't update if you are on miui.
skennelly
Will it update if im on liberty froyo 2.0.1?
it's not going to update from any rom other than stock since 9/10 of them block it's updates. Just do a sbf .
Also updating to an ota update from a rom can have some major issues.
Sent from my droid x via tapatalk
