I have the cryogenic theme installed,but can't find the picture in the download. BlackBackground with red lightning. I have checked wallpapers,etc.
This is a discussion on Shuji 596 rom themes within the Droid X ROMs forums, part of the Droid X Development category; I have the cryogenic theme installed,but can't find the picture in the download. BlackBackground with red lightning. I have checked wallpapers,etc....
Ok... What are you looking for? The wallpaper is missing?
Need to SBF? Try this.
Root .602 & .605 info here.
DROOOID Notification Sound
Gingerbread Red "M" Boot Logo
Froyo White "M" Boot Logo
Trying to figure out where this picture is.
Ok, so I think I'm with you now... That wallpaper may not be a part of the rom or theme. Your best bet would be to download zedge and search those wallpapers. They have quite a few, so if you don't find that one specifically, you will likely find another one that strikes your fancy.
From Shuji on my DX
