repo sync problems in Ubuntu 11.04
This is a discussion on repo sync problems in Ubuntu 11.04 within the Droid X ROMs forums, part of the Droid X Development category; Hey guys, I wanted to know if any of you have experience with compiling android from source using Ubuntu 11.04 x64. I have been having ...
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: repo sync problems in Ubuntu 11.04
    Points: 2,861, Level: 32
    e3zkiel's Avatar
    6303
    California
    216
    11 times
    Hey guys,
    I wanted to know if any of you have experience with compiling android from source using Ubuntu 11.04 x64. I have been having some strange issues with git and repo.
    Thanks,
    e3zkiel
    Nokia handheld -> LG flip phone -> Storm -> Droid X
    ROOTED and lovin' it
    running Android
    4.0.4 - currently using Gummy 1.2.0 - 5/9/12 [BETA]
    Points: 15,172, Level: 79
    Overall activity: 14.0%
    cory46's Avatar
    8051
    4,777
    125 times
    What error are you getting? And I know you said android but are you compiling it or cyanogen?
    e3zkiel's Avatar
    6303
    California
    216
    11 times
    I was getting gingerbread and cyanogenmod's files from repo using git. I have compiled both of them before. Right now I have created a fresh new VM and following cyanogenmod's wiki for the droid x. I have completely downloaded all the files before hand but was just updating them before I did the make command. When I do repo sync, it gets to about 50% fetching projects pauses. From here I have no internet access within the VM even though I do through the host. I can do a sudo ifconfig down and up and that still doesn't fix the internet issues. Then the terminal times out from the repo sync and states
    "android.git.kernel.org[0: 149.20.4.77]: errno=Connection timed out
    android.git.kernel.org[0: 2001:4f8:1:10:1972:112:1:0]: errno=Network is unreachable
    fatal: unable to connect a socket (Network is unreachable)
    error: Cannot fetch blah blah blah (what it's trying to fetch)"
    running Android
    cory46's Avatar
    8051
    4,777
    125 times
    Do you have a firewall set up?
    cory46's Avatar
    8051
    4,777
    125 times
    I didn't see in your post of you have git:// or http:// for android.git. kernel
    Try replacing git:// with http:// that may do the trick
    e3zkiel's Avatar
    6303
    California
    216
    11 times
    not that I don't mind doing this through the forum... is there a DroidXforums IRC channel? No I don't have a firewall set up other than what's standard through windows 7 and dd-wrt from the router standpoint.
    running Android
    cory46's Avatar
    8051
    4,777
    125 times
    Did you change git to http?
    So
    repo init -u http:// *** android kernel git site***
    Then go to your ./repo directory
    ./repo/ manifest.xml rename git://android.git. whatever to http:// android git
    Then ./repo/repo/repo change the git:// in the "tools" repo git ( it'll have tools in the git name) to http://
    e3zkiel's Avatar
    6303
    California
    216
    11 times
    using this site: Motorola Droid X: Compile CyanogenMod (Linux) - CyanogenMod Wiki
    I installed repo using git:// instead of http://
    I could not find the repo directory you were referring to. I found a hidden .repoconfig directory but nothing else.
    Would changing the repo installation from git to http fix my problems? why would they have a git protocol to begin with and then have it only work with http. So stupid...
    running Android
    cory46's Avatar
    8051
    4,777
    125 times
    Yeah git works for me on Linux don't know if it's cause your using a VM or if the android git is being picky I'll find a link that explains it better than i did with that hack job of explanation haha give me a tic
    e3zkiel likes this.
    e3zkiel's Avatar
    6303
    California
    216
    11 times
    cory46,
    Thank you so much for your help! honestly way better than the help I got in the #cyanogenmod irc channel!!!
    running Android
  1. Problems with Facebook sync
    By JonDroid in forum Droid X Help
    Last Post: 07-20-2011, 01:19 AM
  2. Problems with market sync cm7
    By jkelley74 in forum Cyanogenmod
    Last Post: 06-15-2011, 06:16 PM
  3. Sync problems
    By Blueduck3285 in forum Droid X Help
    Last Post: 02-10-2011, 03:57 PM
  4. Sync problems
    By droidxer in forum Droid X Help
    Last Post: 10-06-2010, 09:27 PM
  5. Sync Problems
    By ReDRaideR10 in forum Droid X Help
    Last Post: 10-02-2010, 02:16 PM
android.git.kernel.org[0: 149.20.4.77]: errno=connection refused
android.git.kernel.org[0: 149.20.4.77]: errno=connection timed out
repo connection refused when sync
repo sync connection refused
repo sync connection timed out
repo sync time out
repo sync timeout
repo sync ubuntu
ubuntu repo sync
