This is a discussion on Apex 1.4.0 - wont get past boot animation! Help! within the Droid X ROMs forums, part of the Droid X Development category; Originally Posted by bsbabcock Syntax question: Is what the OP experienced the thing I've heard described as a "bootloop"? a "bootloop" is when you're phone ...
Rooted, Modded Droid X Running MIUI.
Need something photoshopped? Request it here.
i downloaded cyanogenmod on sd card booted into recovery-( power on while holding volume down first). enter recovery then restore via sd find the zip file. then restore. after it still wouldnt work so i factory reset and the rom was still loaded and cleared cache i waas worried about losing the flash from verizon to metro but everything worked perfect. cyanogen is hella better than any rom ive used. phone must be rooted
